Suspension & Brakes Theory, alignment, spring rates....
Drum Brakes to Disc brake conversion using drum brake trailing arms
Old Sep 5, 2012 | 08:43 AM
JDMCRX's Avatar
Default Drum Brakes to Disc brake conversion using drum brake trailing arms
Ok question im having issues finding ABS disc brake assembles.
I have a few non ABS disc trailing arms. Can i just swap all the parts over using the drum trailing arms ??
Old Sep 5, 2012 | 09:25 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Drum Brakes to Disc brake conversion using drum brake trailing arms
Scarebird.
Old Sep 5, 2012 | 10:03 AM
JDMCRX's Avatar
Thanks ill do the brackets so much easier
Old Sep 6, 2012 | 05:15 AM
spAdam's Avatar
Loved
Community Favorite
Yes you can just unbolt the spindles and transfer them over to whatever arms you have. They are held to the arms with 4 large Torx bolts (T50? Can't remember exactly). No problems.
Old Sep 11, 2012 | 06:49 AM
emagdnLm's Avatar
Use heat on the Torx bolts and they should come out no problemo. They usually have blue lock-tight on them
trillzilla
Suspension & Brakes
Oct 17, 2015 04:56 PM
VegasEg8
27
May 16, 2014 11:38 PM
FearTheH
14
Apr 23, 2009 07:20 PM
2DoorBandit
12
Jul 7, 2006 12:14 PM
