Suspension & Brakes Theory, alignment, spring rates....
Ground control/koni settings
Old Sep 5, 2012 | 06:25 AM
Deathcab's Avatar
Default Ground control/koni settings
I just received these in the mail.
I am installing them tonight and was wondering if anyone has any insight into where I should have the adjusters set as a starting point? Should I put them in the middle and just go from there?
Also the C-clip that the coil sleeve sits on is in the middle position. Is that the best option?
The car is a 98 coupe.
Old Sep 5, 2012 | 07:17 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Ground control/koni settings
Best for what? Put them on and start adjusting. Plan on an afternoon of tweaking.
Old Sep 5, 2012 | 07:55 AM
Deathcab's Avatar
Yeah I figured that. Just looking to see where peoples adjusters are and how their car sits. Also any install tips.
Old Sep 5, 2012 | 08:12 AM
jdmem205's Avatar
Just put them on how they are now and see how it looks once you have the car on the ground see if you wanna go lower then make your adjustments.
Old Sep 5, 2012 | 09:40 AM
tron_'s Avatar
10 Year Member
When you install them, jack up the tire/LCA and approximate the fender gap you want.
Old Sep 6, 2012 | 03:35 AM
ribal_gh's Avatar
Hey man,
What spring rates did u get? and how does the car rides?
post a pic for the new set up
mt-fly-boy-25
Suspension & Brakes
42
May 31, 2014 03:21 PM
exquiisite_101
Mar 17, 2011 02:51 PM
shoryukenz
Suspension & Brakes
18
Jun 3, 2010 06:54 PM
jspeed77
Suspension & Brakes
Apr 7, 2006 07:31 AM
chrisv76
Apr 21, 2002 10:14 PM
