is honda dw-1 the best atf to use?
Old Sep 5, 2012 | 05:58 AM
wasp9166's Avatar
Default is honda dw-1 the best atf to use?
or is there a cheaper but just as good alternative?
Old Sep 5, 2012 | 06:38 AM
crx_si-r's Avatar
Default Re: is honda dw-1 the best atf to use?
never heard of "dw-1" i know there is atf-z1
Old Sep 5, 2012 | 07:07 AM
wasp9166's Avatar
it replaced the z-1
Old Sep 5, 2012 | 08:22 AM
91 EF DX's Avatar
Castrol import multi-vehicle automatic transmission fluid is pretty good. I run it in my wagon and don't feel any slipping and i pull a trailer from time to time
Old Sep 5, 2012 | 10:57 AM
wasp9166's Avatar
you pull a trailer with an auto civic? damn
i got the dw-1
$8.30 a piece at dealer, what ya gonna do.........not gonna do the 3x3, just gonna drain and refill and do again in 20k, i'm sure it mixing with z-1 won't be an issue
i'm doing a ton of work now at 210k, i need it to last me a while and all ready did entire brake system, tie rod ends, upper control arms etc
Old Sep 7, 2012 | 01:17 PM
wasp9166's Avatar
when you check the atf, i know operating temp, car off but
i've read conflicting things , do you push the dipstick all the way back in or just set it on rubber on top of hole to check?
Old Sep 8, 2012 | 08:59 AM
9honda5civic's Avatar
Run the car to operating temp shut the car off now wait 30 seconds then pull the dipstick wipe it off push the dipstick all the way back in then pull it out again and get your reading rhats what we do here at honda
Old Sep 8, 2012 | 09:22 AM
wasp9166's Avatar
ty
cuz the back of the owners manual says to not force rubber plug in, and i had no idea wtf they were talking about
Old Sep 8, 2012 | 09:54 AM
Dont force it or itll rip it should just slide in with a little bit of resistance noting major lol
Old Sep 8, 2012 | 10:49 AM
wasp9166's Avatar
exactly, i'm not sure why you would need to force it ????
Old Sep 8, 2012 | 12:21 PM
jchope's Avatar
ive used import atf from auto part store and honda atf i would recommend honda atf thats what my car ran best with
hawks85
20
Jul 19, 2017 03:33 PM
dejay2014
Mar 4, 2014 10:17 PM
Ruddy Chung
Honda Civic (2001 - 2005)
May 12, 2013 04:36 PM
mcd7
Oct 6, 2011 10:52 AM
sony224422
Mar 31, 2006 06:56 AM
