24 Hour of Lemons with P72
Hello,
I'm building LeMons car with an ls/vtec motor and P72 ecu. I cut off A,B,and D harness off the ecu. I'm planning on plugging all the sensors for engine into ecu with my own direct wires. Question is will the engine run or did I need anything from the body harness?
Thanks!
-Michael
Thanks!
-Michael
Whether the engine runs or not really all dependents on how you wire it up!
I'm going to assume that you have a wire diagram for the chassis you removed the harnesses from. Yes/No? You really should if you don't already. It will show you if there are any wires from the ECU that switch over to the body harness.
Yes as long as you have all of the required PGM-FI (engine) related sensors. If the P72 is chipped you could even get away with running fewer sensors. Depends on the software you use for tuning.
