CV Half-Shaft Axel question (torn boot) -_-
I have a 92 Civic Sedan with a 96 integra type r engine swap and I discovered today that the boot on the drivers side CV axel is torn. Do I have to get a CV joint from an Integra Type R or can I use an application from another car?
Thanks in advance!
Thanks in advance!
before todd throws a fit and gets your thread moved the answer is probably as stated above. only the 98+ jdm axles are different and they are made to fit the 98+ jdm suspension and hubs. in every other application you use a standard integra axle with the abs ring
civicguy395
Dec 13, 2012 03:18 AM
