Tires for a 97 del Sol
Old Sep 4, 2012 | 04:12 PM
dhazeghi's Avatar
Default Tires for a 97 del Sol
Hello,
I'm looking to replace the tires on my 97 del Sol (VTEC). The current set - Michelin Pilot Exalto A/S - have done around 55k miles. I was just going to replace them with the same. Unfortunately I've not found anybody (Costco, Sears, Wheelworks, etc.) with the correct sized ones (195/60R14) in stock.
I did notice that Michelin now have a 'Defender' brand which is warrantied to 90k miles, which would be nice, but they only come in 195/70R14. Does anybody know if these would fit the del Sol?
Beyond that, if anybody knows of a good source for the Michelins in the bay area, or has other recommendations for good long-lasting tires, I'd be very interested to hear about them! Thanks,
DH
Old Sep 4, 2012 | 04:23 PM
jdmh22eg2's Avatar
Default Re: Tires for a 97 del Sol
Yes 70's will fit a sol, 10mm is not much it will look goofy with truck sized sidewall, but if u have to have 90k out of them so be buy them, personally i will never buy a michelin tire but hay its all what u want
Check this link to tire rack and your current sized tires. I think discount tire (if you have them in your area may be a dealer for them)
http://www.tirerack.com/tires/TireSe...60&diameter=14
Old Sep 4, 2012 | 06:12 PM
jbpnoman's Avatar
No, do not put 195/70r14s on your car. They will make your speedometer read incorrectly. 14 inch wheels are getting harder and harder to find the correct tires for. 205/55R14 or 185/65R14 would be proper alternate sizes.
Old Sep 4, 2012 | 06:22 PM
toyomatt84's Avatar
Sanji
Its not 10mm, its 10%. Which, for a 195 treadwidth, is actually a 19mm difference. Which is also nearly an inch, and extremely oversized for the chassis.
Old Sep 4, 2012 | 09:06 PM
dhazeghi's Avatar
I see. I'll take a look then for those other sizes.
Would you have any particular recommendations for tires? Snow isn't an issue (don't have it around here), but something that handles the rain and will last would be much appreciated.
Ah, okay, got it. Thanks!
DH
Old Sep 5, 2012 | 09:32 AM
sohc95vtec-t's Avatar
Still plenty of options out there in that size. Heres a start:
also, the s, and si model del Sol's come factory with a 185/60-14 which also would not be a bad size for your vtec model. The same Michelin's you currently have are available in this size as well
Old Sep 6, 2012 | 02:25 PM
doc@tirerack's Avatar
WE hope to get the Pilot Exalto(195/60R14) back in stock in a few weeks. If you need something else, consider the BFG Super Sport AS as the closest replacement (as they are manufactured by Michelin.
sol_cal
Sep 20, 2014 04:37 AM
97dssi
Mar 27, 2011 12:55 PM
dhoff024
17
Aug 3, 2009 07:37 AM
Synbios
Mar 13, 2007 03:17 PM
Family Man
Jan 10, 2005 08:52 PM
