Transmission & Drivetrain Gearboxes, Differentials, Clutches
3rd gear hard to get into on downshift
Old Sep 4, 2012 | 09:03 AM
my96GSRteg's Avatar
Default 3rd gear hard to get into on downshift
this problem only started in the last week or so and is pretty consistent. I have a stock b18c1 tranny with 180k on it that is hard to get into 3rd but only when i downshift from 4th. When i move the selector forward into 3rd, there is a hard stop, then i have to push forward even harder to get it into gear. Going up through the gears is no problem though.
Yes, the clutch is completely disengaged when this happens and i put amsoil MTF in it about 6 months ago. I dont know enough about transmissions to diagnose this problems so any help is appreciated.
Old Sep 4, 2012 | 10:43 AM
Gearspeed-Performance's Avatar
Default Re: 3rd gear hard to get into on downshift
I would say the selector,shift fork, or slider sleeve/hub would be the first things I would look into. I have seen some instances in a car with high mileage, where the hole actually wore oblong where the selector pin sits, and the selector was moving around slightly and would make certain gears really hard to get into on certain movements.
Old Sep 4, 2012 | 11:06 AM
my96GSRteg's Avatar
thanks i appreciate your help!
Old Sep 4, 2012 | 12:13 PM
Honda Bull's Avatar
Yeah. I'd look into the same things. As stated, the shift fork bushings definitely wear sometimes (can't really replace JUST them either). I've even had an upper case somehow get damaged to where the 5/R fork bore was misaligned and would jam up in reverse. Transmissions do weird things. :S
Old Sep 4, 2012 | 12:19 PM
Yes the bores in the case too, I forgot to mention that. Good stuff Bull. I have experienced the exact same thing with the reverse lock out on a mis-aligned/worn case.
Old Sep 4, 2012 | 10:25 PM
my96GSRteg's Avatar
thanks guys! its clearly way over my head so im just gonna deal with it until it becomes more of a problem.
infamouskillas
May 17, 2008 09:56 PM
crzyfool24
11
Sep 26, 2004 09:48 PM
ChillOutWayne
Jul 31, 2004 10:35 PM
chris408
Apr 22, 2004 03:51 PM
2qwik2nv
Apr 11, 2002 02:56 PM
