Car wont start hondata problems think please help
Old Oct 16, 2002 | 03:41 PM
oscargsr's Avatar
Default Car wont start hondata problems think please help
About a week ago I was driving my 96 gsr turbo charged. With hondata stage 2b. And it was about 2 in the morning and all of lights started to go dim. Alternator problems. My car eventually cut off from loss of power. I finally got it home and I let it sit for a few days then I had to move the car up the driveway . I put jumper cables on the car and it started fine and I drove up the driveway. I then let it sit for about a week and i did a quik fix for the alternator (bad connection).I tryed to start the car again last night and again tonight and it doesn't wont to start.what the ****. I'm so pissed of cause I put sooooo much money into the car and it doesnt even want to start. Please help if you have any IDEAS. thanx
oh yeah is it possible that the hondata lost its program?
Old Oct 16, 2002 | 03:53 PM
ekb18c's Avatar
Default Re: Car wont start hondata problems think please help (oscargsr)
hondata can lose it's program . lol
Check your battery.
[Modified by ekb18c, 1:12 AM 10/17/2002]
Old Oct 16, 2002 | 04:01 PM
oscargsr's Avatar
Default Re: Car wont start hondata problems think please help (ekb18c)
Actually I just found out that it cant lose it's program. So thanx for NOTHING!
Old Oct 16, 2002 | 04:02 PM
MikeMAN's Avatar
i think he was being sarcastic
Old Oct 16, 2002 | 04:06 PM
Farnsrocket's Avatar
Default Re: Car wont start hondata problems think please help (MikeMAN)
you're battery is screwed.........how old is it?
Old Oct 16, 2002 | 04:10 PM
IntegD's Avatar
New User
Default Re: Car wont start hondata problems think please help (Farnsrocket)
Damn dude, chill out. Either your battery or alternator is having a problem. You can take your battery out and take it to autozone or pep boys and they can check it for you and tell you if its bad. If it is, there ya go, if not, take the alternator to them and they can check that for you as well.
Old Oct 16, 2002 | 04:13 PM
oscargsr's Avatar
Default Re: Car wont start hondata problems think please help (IntegD)
I hooked up jumper cables to the car so it should start.The alternator has nothing to do with it, all it does is keep the charge.The car trys to start but will not fire.
ekb18c's Avatar
Gosh, I was mearly being sarcastic, sorry if you didnt find that funny. I did say check your battery.
Old Oct 16, 2002 | 04:15 PM
ekb18c's Avatar
next step now is check your fuel and spark.
Old Oct 16, 2002 | 04:17 PM
IntegD's Avatar
New User
So does it sound slow or does it just wind like normal except it doesnt start?
Old Oct 16, 2002 | 04:21 PM
FredoSP's Avatar
fuse? My buddy had this problem, it was pink fuse (50 or 70 amp), under the hood.
I think this is your problem, let us know.
Old Oct 16, 2002 | 04:38 PM
oscargsr's Avatar
Default Re: Car wont start hondata problems think please help (FredoSP)
The starter sounds strong I did check the fuses the other day and I didn't see anything but I will check them again now.
Old Oct 16, 2002 | 04:52 PM
oscargsr's Avatar
I checked the fuses none are blown. Is the fuse U are talking about the IG fuse 50 amp. a big fuse that is held down by 2 phillip screw's?
Old Oct 16, 2002 | 04:58 PM
IntegD's Avatar
New User
Yeah I think thats the one he is talking about. So it doesnt sound slow starting? It sounds just fine?
Old Oct 16, 2002 | 05:02 PM
oscargsr's Avatar
Yah it sounds strong. I pulled out the plugs and the plugs are covered in gasoline.
Old Oct 16, 2002 | 05:06 PM
oscargsr's Avatar
Sometimes the car will start but very rough idle. fuel pressure showing 60 psi. If i let go of the gas pedal car cut's off. It also seems like I might have a vacumm leak. the car was reving. But the wierd thing is that I didnt have any of these promblems before.
Old Oct 16, 2002 | 05:11 PM
Hondata's Avatar
This is not anything to do with Hondata. A Honda ECU will start a car in limp home mode if the chip or even if the main microprocessor is removed.
Check Spark and fuel.
Check current drain from the battery with the key off.
Old Oct 16, 2002 | 05:27 PM
oscargsr's Avatar
Default Re: Car wont start hondata problems think please help (Hondata)
How do I go about checking the fuel? I have recently put rc550's in. I smell gas when it is trying to start. the fuel presure is at 60psi. And also how do I check the drain from the battery? Multimeter
Old Oct 16, 2002 | 09:28 PM
FredoSP's Avatar
This might be a dumb question, but you have a resistor box with those 550's right?
Old Oct 17, 2002 | 07:50 AM
Zeppelin's Avatar
You have 60 psi of fuel pressure at idle with 550cc injectors? I may be wrong but that seems too high. My car runs rich at 45 psi(removing vacuum line from regulator) and 220cc injectors!
bukkake
Jun 16, 2007 10:10 AM
JB20VTEC
Dec 29, 2004 03:13 PM
superfuji57
Aug 8, 2004 07:44 PM
threatcon13
Feb 10, 2002 08:36 PM
