need help!!! ef9 power window wiring for lhd switches
Old Sep 3, 2012 | 06:59 PM
89civicstd's Avatar
Default need help!!! ef9 power window wiring for lhd switches
need help wiring my lhd window switches on my ef i already have it wired for the jdm ones but as soon as i plug the lhd ones the passenger side goes up any one has a diagram for the lhd switches..
Old Sep 3, 2012 | 07:39 PM
crx_si-r's Avatar
Default Re: need help!!! ef9 power window wiring for lhd switches
the master switch wirng is differnent on LHD vs RHD. your fuse should be blowing, you do have a fuse in line for power wire right. if not, you may have damaged the switches. did you already have rhd switches working?
Old Sep 3, 2012 | 07:49 PM
89civicstd's Avatar
i have the jdm ones wired and its fused so i dont think i damaged the switches. i want to wire the ldh switches but cant find a diagram for it. i just keep finding the jdm one
Old Sep 3, 2012 | 09:05 PM
crx_si-r's Avatar
are you using oem wiring or did you swap out the wiring? at the plugs i mean. if you did swap them post a pic of your plug i can tell you what needs to be moved around
Old Sep 3, 2012 | 09:41 PM
89civicstd's Avatar
am using the oem wiring ill post pic in a bit
Old Sep 3, 2012 | 09:52 PM
89civicstd's Avatar
posted pics
Pandahatch
Mar 6, 2007 06:34 PM
projektvtec
10
Sep 25, 2005 07:42 AM
JDMEJCIVIC_CTR
May 1, 2005 05:19 PM
*Boostwerks*
Jan 20, 2005 06:48 AM
