MASSIVE 96-00 Civic Ex/Si & 94-97 Integra FS List
Old Sep 3, 2012 | 07:10 AM
mayfieldfour's Avatar
Default MASSIVE 96-00 Civic Ex/Si & 94-97 Integra FS List
This post cleans up the sold items and adds new pictures and pricing frmo my previous threads.
I’ve parted out a few cars over the last year, and here are the remaining parts I have left. I ONLY have these parts and no others available. Please read through the list (I realize it’s long, but it will save you and I time in the long run) and if there’s something on there you want, TEXT ME and we can work something out.
All prices are best offer unless stated otherwise. Willing to ship unless item says otherwise. Paypal is accepted, but buyer must include 3% paypal fees. Listed prices do not include shipping fees.
I work 5 minutes south of the Dayton Mall. Parts are available for pickup during the week at my S. Dayton office monday - friday, 8:30a-5:30p. Any other time and you will have to come to my house.
TEXT ME ANY QUESTIONS: (five 1 three) two 5 three - 6 six 6 zero
All emails will be ignored... and I don't answer phone numbers I don't recognize. Please only text me!
1996 Civic EX Coupe 5spd and 2000 Civic Si 5spd Coupe Parts.
- Specifically removed from these year/models but in most cases will fit 96-00 & even 92-94 Civics:
(NOTE: The following parts were removed from a 1996 Civic EX 5spd)
- d16y7 clutch, pressure plate ****SOLD LOCALLY****
- d16y7 flywheel. Unknown mileage but still some life - $15
- 96-00 EX (will fit cx, dx, hx, lx, ex, si) rear LCAs. Will need new bushings -- $10
- 96-00 Civic all models cluster bezel -- ****SOLD****
- 96 EX SRS brain. Should fit all models 96-00, but buyer to confirm -- $10
- 96 EX engine bay fuse boxes. Should work with all models 96-00; buyer to confirm
- (1) loaded fuse box with cover -- ***SOLD TO AN HT MEMBER***
- (1) empty fuse box with cover -- $5
- 96 EX driver and passenger front brake calipers. Non-ABS. Should fit all model 96-00 Civics; buyer to confirm -- $15 each or $20 for the pair
- 96 EX underdash fuse box. Should fit all model 96-00 civics. Buyer to confirm. Loaded -- $10
- 96-00 Rear view mirror -- ****SOLD LOCALLY****
- 96-00 Civic CX/DX/HX/LX/EX flywheel cover ****SOLD to spazzz84 ****
- d16y7 header heat shield. Rusty but no oversized holes. -- $5
- 96 EX engine bay cruise control unit. Should fit all model 96-00 Civics; buyer to confirm -- $10
- 96-00 Civic all models (except Si) clutch slave with hard to soft lines ****SOLD to EKevans08****
- 96-00 Civic all models (except Si) upper and lower radiator hoses. No rips, cracks or tears -- $5
- 96-00 Civic all models positive battery cable; battery to fuse, battery to starter -- $5
- 96-00 d16y8 Intake Manifold, 5spd. Bare ****SOLD to EKevans08****
- 96-00 Civic all models, sun visors. Need re-covered -- $5
- 96-98 climate control box -- $15
- 96-00 d16y8 5spd throttle cable - ****SOLD****
- 96-00 d16y8 VTEC control switch (solenoid) ****SOLD****
- 96-98 d16y8 (may fit other engines) main relay -- ****SOLD****
- 96-00 d16y8 (probably y7 also; buyer to determine) lower timing belt cover - $10
- 96-98 d16y8 (probably y7 also; buyer to determine) middle timing belt cover (behind cam gear) - $5
- 96-98 Switches; (2) rear defrost, (1) hazard -- $5 each, 2 for $8, 3 for $10
- 96-98 Coin Pocket -- $5
- d16y8 Head. ****SOLD*****
- d16z6 Valve Cover. ****SOLD to a D-series memeber****
- d16y7 valve cover. ****SOLD to a D-series memeber****
- d16y8 AEM 3-bolt red cam gear. ****SOLD to a D-series member****
- d16y8 OEM cam gear -- $10
- d16y8 (might fit y7; buyer to determine) aftermarket IM gasket. Used - $20
- d16y8 Delta Cam 260 regrind. Brand new, never installed. Bought through a group buy last year for $112 plus the core -- ****SOLD****
- (1) 96-00 Civic armrest in light gray. ARMREST ON LEFT IS SOLD! One is missing one of the dead buttons (the ones I have are dark gray... I can include one with the sale, but know that the color is off a bit). Both are in overall good shape and include the back cover as well (that faces the rear seats). The arm pads show some wear adn could use a cleaning. Both mount/open/close just as they should with no cracks or issues. -- $40
- Driver side dash vent *****SOLD LOCALLY*****
- Pass side dash vent -- $10
- Sun visor clips (2) *****SOLD*****
(NOTE: The following parts were removed from a 2000 Civic Si with the dark gray interior)
- Shifter console with black aftermarket boot ****SOLD****
- Tweeter pods (previous owner kept tweeters) -- ****SOLD****
- door sills --****SOLD LOCALLY****
- front kick panels -- ***sold to Zhu926****
- Rear panels $40 for pair; won't separate(I also have a set of rear hatchback panels for sale for $40)
- cigarette lighter panel -- $15
- Both Front seats. ***SOLD LOCALLY***
- b16a2 power steering high pressure hose ****SOLD****
- b16a2 OEM Honda flywheel. ****SOLD****
- 99-00 Floor harness. ****SOLD****
- Glove box -- $20
- 5spd pedals. Won’t separate ****SOLD to EKevans08****
- Pass Side airbag ****SOLD LOCALLY****
- Driver Side window motor. ****SOLD LOCALLY****
- b16a2 Cruise control cable -- $10
- Underdash fuse box. Bare -- $5
- Driver Window Switch - ****SOLD to inzane****
- Dead pedal -- $3
- Dash side covers -- $5 each, $8 for pair
- SRS Reel -- ***sold to sik_one***
- 96-00 All models Civics Driver side dash vent with dimmer and cruise switch. ****SOLD****
- 96-00 All Models Civics Pass side dash vent****SOLD****
- 7/8 Brake Master Cylinder -- $30
- (2) rear deck brake lights. Should fit all 96-00 Coupe or Sedan Civics. - $3 each
- Both Inner Coupe trunk lights. ****SOLD LOCALLY***
- Passenger side outer tail light. ***SOLD LOCALLY****
- 99-00 Si Engine Bay cruise unit -- $10
- MSD Blaster SS (p/n: 8207) and MSD Cap ****SOLD****
- Front harness that goes to radiator fan, horn and turn signals – Complete and uncut. -- $30
- Coupe Pass window motor. ****SOLD LOCALLY****
- Pass rear corner garnish. Milano Red No dents or scratches -- $15
- Gas door. No dents or scratches. Milano Red -- $15
- 00 Civic Keyless entry brain. P/N: 3830-S04-A020-M1. ***SOLD TO AN HT MEMBER***
- 99-00 Si Cruise Control Brain. O/N: 36700-S01-A61 -- $10
- 99-00 Positive cable; battery to starter and battery to fuse box. Includes aftermarket terminal -- $8
- 96-00 Battery Tray. Milano Red ****SOLD****
- Driver, Passenger, center REAR seatbelts. Should fit coupe or sedan. Buyer to confirm fitment. $8 each, $15 for all 3
- 00 Civic EX Owners manual ****SOLD****
- 96-00 Civic Dark grey e-brake arm -- $10
- 40/40 Prop Valve ****SOLD****
- 5/8 Clutch Master Cylinder -- $20
- 99-00 Passenger side foglight garnish. ****sold to Zhu926****
- 96-00 dark gray sunroof switch -- $10
- 96-00 Power Mirror switch. ***SOLD TO AN HT MEMBER***
- 96-00 Driver side coupe door lock (what latches door to frame) -- $5
- 96-00 Rear View Mirror ****SOLD LOCALLY****
- 96-00 Civic Head light switch arm ***SOLD TO patfl1***
- 96-00 Skunk2 lowering springs on OE struts. ****SOLD LOCALLY****
- 96-00 Civic Dark Gray Coupe door sills ****SOLD LOCALLY****
- 99-00 Si OE style radiator ****SOLD****
-99-00 Si AC Hardlines ****SOLD****
- 99-00 Si AC Condenser ****SOLD****
- 99-00 Si rear floor subframe brace (Gusset). Bolts to the floor under rear seats. -- $40
- AEM cold air intake. ****SOLD LOCALLY****
- 96-00 Civic dark gray door handle (interior) -- $5
- Random bump Stops -- $3 each, $8 for all
- BMW (forget what year) 3-Series amber side markers. Includes enough wire to wire up -- $5
- 96-00 Civic eyelid (1) only -- $5
- Honda free pocket (pulled from a 94 Accord, but should fit any Honda) -- $5
- 6-1/4” Kenwood speaker grills -- $10
- 6” x 9” Cerwin Vega speaker grills -- $10
- 6” x 9” Kenwood speaker grills -- $10
Various Honda and other parts:
- BNIB Airtrex electric in-tank fuel pump. Fits a broad range of Hondas. P/N: E8335 -- $20
- H22 OEM oil pressure sending unit. Used but worked when pulled - $5
- Resistor Box (specifically from an Accord F22 motor) - $10
- d16y8 (possibly y7 & z6; buyer to determine) Stant Thermostat switch. Needs gasket. P/N: 13878 -- $5
- BNIB H22 OEM Honda timing Belt Tensioner stopper. P/N: 14540-P13-003 -- $5
- BNIB F22 OEM Honda oil seal. P/N: 91213-PTO-003 -- $5
- BNIB 3-pack of Autometer angled gauge pods ****sold to HT member****
- Bass Box tubes - $5 for all
- (2) 12” sub grills. Includes sub box mount clips -- $5 each, $8 for both
- 10” sub grill, includes sub box mount clips - $5
- (1) Accord floor mat emblem -- $2
- (2) Accord trunk emblems -- $2 each
- Special Edition (from an Accord) trunk emblem -- $2
- 92 Integra 5spd shift **** -- ****SOLD LOCALLY****
- d16y7, d16y8, d16z6 BNIB OEstyle valve cover grommets -- $5
- (3) Civic armrest plugs. Dark gray -- $1 each
- (1) Civic Hatch (96-00 at least, possibly 92-94) trunk plug ***SOLD TO patfl1***
- (2) 94-97 Honda Accord center console plugs (generally for the left/right of clock) -- $1 each
- (1) Civic dark gray plug. Fits where sunroof/foglight switches go - ***SOLD TO patfl1***
1994 Acura Integra LS 5spd coupe:
- Specifically removed from a 94 Integra in most cases will fit 94-97 & even 98-01 Integras:
- Sun Visors, overall good shape but a bit dirty. Won’t separate -- $10
- OEM Front lower Tie bar - ***SOLD TO JZiggy***
- DOHC Fender moldings. Won’t separate - $10
- BNIB Fel-Pro B18A, B18B cam seals. P/N: TCS 45718 -- $5
- Coupe Pass Window Switch -- $10
- Coupe (may fit sedan; buyer to determine) driver & passenger door handles/locks -- $8 each, $10 pair
- Dome light -- $3
- 94 Integra Owners manual -- ***SOLD to JayVee***
- 94 Integra Climate Control. Should fit all model 94-97 Integras -- $25
- Door panel pockets ****SOLD LOCALLY****
- (1) cruise, (1) dimmer switch -- $6 each, both for $10
- 94 Integra main relay -- $15
- 94 Integra ABS motor relays -- $5
- Head light switch/arm ****SOLD LOCALLY****
-Integra Rear Trunk carpet. ****SOLD****
- 94-97, likely 98-01 (buyer to confirm) Driver and passenger coupe window motors -- $25 each, $40 pair
- 94 Integra coupe (don’t think it fits sedan; buyer to confirm) light gray A pillar trim - $20
- 94 Integra Cruise control unit -- $10
- 94 Integra underdash fuse box. Loaded - $10
- 94 Integra LS coupe engine bay fuse box with cover. Loaded -- $10
- 94 Integra LS rear sway bar. ****SOLD****
- 94 Integra coupe rear speaker pods -- $10 for pair
- 94 Integra 5spd pedals. ****SOLD****
- 96 Integra GS dark gray leather headrests. Minor cracking in the driver, but overall in good shape. Won’t separate -- $35
- 94 Integra hood latch and cable -- $10
- 94 Integra 5spd clutch slave -- $10
- 94 Integra ABS brain - $5
- 94 Integra Cruise control brain - $5
- 94 Integra coupe dark gray driver and passenger front seatbelts - $8 each, $10 for pair
- 94-97 Integra coupe dark gray gas door. Should fit sedans also (buyer to confirm) -- $10
- 94-97 Integra battery bracket and posts - $5
- dead pedal - $3
- gas cap - $3
- 94 Integra front strut forks. ****SOLD LOCALLY****
- 94 Integra charcoal can - $5
- 94 Integra positive battery cables; battery to starter, battery to fuse -- $5
- 94 Integra rear upper strut top hats. Won’t separate **** SOLD TO VTEC_Du_Ma_Mai****
- 94 Integra 5/8 Clutch master slave - $10
- Various Motor Mounts:
- D16y7 y8 T- Bracket -- $20
- D-series pass side torque brackets (2) -- $5 each
- B16 Torque pass side torque bracket -- $5
- B18 pass side torque mount (not shown) -- $5
- d16z6 driver side post mount -- $10
- d16z6 pass/alt brackets (forget which is which) -- $5 each
- b18b1 driver side post mount and mount (no rips) - $15
- b18b1 upper PS puimp bracket (not shown) -- $5
(3) sets of used lugnuts. All have, at one time or another, been on a Honda: 94-97 Accords, 90-93 & 94-97 Integras, 96-00 Civics. These should fit any vehicle with the same 12x1.5 lug thread:
- OEM Honda set of 16. ****SOLD LOCALLY****
- Aftermarket lug set #1. Used with OEM Honda steelies. Might not fit some aftermarket rims -- $15
- Aftermarket lug set #1. These are a skinnier set and I’ve used these with a number of aftermarket rims including Rota, Enkie, Drag and Motegi rims. Includes the lug key -- $15
Below are items I do NOT currently have pictures of, but can get and send:
- 94-97 Integra Coupe dark gray rear panels. Include strut covers. Won’t separate -- $30
- 94-97 Integra LS front knuckles with calipers and upper A-arms. Will need new lower ball joints. $15 per side, $25 for pair
- 94-97 Integra coupe, ****SOLD LOCALLY****
- 96-00 Civic coupe driver side window glass -- $15
- 96-00 Civic all models keyless entry fob -- ****SOLD****
- 96-00 Civic Hatchback rear panels. Dark gray. Won’t separate -- $30
- 96-00 Civic Hatchback rear speaker panels. Won’t separate -- $25
- 96-00 Civic coupe dark gray rear panels (specifically from the Si). Won’t separate -- $30
- 94-97 Integra LS radiator overflow bottle ****SOLD LOCALLY****
Old Sep 3, 2012 | 07:35 AM
AznRicer123's Avatar
Default Re: MASSIVE 96-00 Civic Ex/Si & 94-97 Integra FS List
bump
Old Sep 3, 2012 | 09:47 AM
^^^^Thanks
Updated a few items that just sold locally
Old Sep 4, 2012 | 06:09 PM
Si taillights,keyless brain, mirror switch and Lodaded Civic fuse box, all SOLD
Old Sep 9, 2012 | 11:14 AM
Sold a bunch since my last post. As I've mentioned, text is the fastest way to get ahold of me and have the best shot at parts. The list above has been updated, but here's a list of what was sold:
-Si 40/40 prop valve
- z6 valve cover
- y7 valve cover
- b16 flywheel
- y8 VTEC switch
- Civic shifter console
- Si tweeter pods
- Driver and pass dash vents
- Integra shift ****
- Civic gauge cluster bezel
- Gasket set #1
- Gasket set #2
- Civic owners manual
- Si AC concenser
- y8 throttle cable
- AEM cam gear
- Skunk2 radiator cap
- Skunk2 shifter
Old Sep 11, 2012 | 10:59 AM
Tkrizz's Avatar
Would it be possible to get pics of the 94-97 Integra LS front knuckles with calipers? Thank you.
Old Sep 11, 2012 | 02:50 PM
joexiong's Avatar
Never got a text back from ya about the civic window motor
Old Sep 12, 2012 | 04:23 PM
I can, but I can't imagine shipping to ND is going to be cheap. Text me and I'll send you a picture tomorrow
Must not have received it.... send it again: 513-253-6660
Si Key Fob sold locally
Old Sep 14, 2012 | 04:20 PM
Si Seats ***SOLD LOCALLY***
Integra Owners manual ***SOLD tp JayVee***
Old Sep 15, 2012 | 08:56 AM
TTT
Old Sep 26, 2012 | 04:19 PM
The following parts have all been sold:
Megan mid-pipe - ****SOLD LOCALLY****
Si rear view mirror - ****SOLD LOCALLY****
AEM CAI - ****SOLD LOCALLY****
Si Door Sills - ****SOLD LOCALLY****
skunk2 springs - ****SOLD LOCALLY****
Integra driver window glass - ****SOLD LOCALLY****
Si - headliner - ****SOLD LOCALLY****
Si driver window switch - ****SOLD to inzane****
Old Sep 27, 2012 | 08:25 AM
Vacation Day bump
Old Sep 30, 2012 | 08:00 AM
Back up top
Old Oct 6, 2012 | 05:47 PM
y7/y8 flywheel cover ****SOLD****
Old Oct 7, 2012 | 04:53 PM
I've got a few other new items to list now as well:
- (2) 96-00 Civic arm rests in light gray. One is missing one of the dead buttons (the ones I have are dark gray... I can include one with the sale, but know that the color is off a bit). Both are in overall good shape and include the back cover as well (that faces the rear seats). The arm pads show some wear adn could use a cleaning. Both mount/open/close just as they should with no cracks or issues. -- $40 each... first buyer can choose which they want
- Driver side dash vent with cruise and dimmer buttons -- $15
- Sun visor clips (2) -- $10 shipped
Text is the fastest way to get ahold of me!
Old Oct 10, 2012 | 04:50 PM
TTT
Old Oct 11, 2012 | 05:43 PM
94 Integra rear upper strut top hats. **** SOLD TO VTEC_Du_Ma_Mai****
Old Oct 13, 2012 | 05:01 PM
Old Oct 14, 2012 | 11:23 AM
TTT
Old Oct 16, 2012 | 04:25 PM
Pictures have been edited for what's been sold.
Listening to offers on anything and everything.
Old Oct 17, 2012 | 05:05 AM
EJ8freek's Avatar
Bump. U got PM.
Old Oct 19, 2012 | 12:05 PM
Originally Posted by EJ8freek
Bump. U got PM.
PM replied
Back to the top
Old Oct 21, 2012 | 06:29 AM
Bump
Old Oct 22, 2012 | 01:54 PM
Monday bump
Old Oct 25, 2012 | 05:00 PM
TTT
