Honda CR-V & Element 2WD & 4WD Element & CR-V
grinding/scraping noise when making u-turn
Old Sep 2, 2012 | 08:19 PM
Ghetto Civic HX's Avatar
I love to drive
Icon6 grinding/scraping noise when making u-turn
I just test drove a '99 CR-V LX AWD with 175,000 miles. Everything on the car is great except there's a grinding/scraping noise that seems to be coming from the front left wheel when making a very tight u-turn. Like you have to have the steering wheel completely turned to the left to make it make the noise.
I've read that old rear dif. fluid can cause a noise when turning, but what other things should I consider? Wheel bearings, CV joints, etc.
Old Sep 3, 2012 | 12:21 AM
LDForget's Avatar
Default Re: grinding/scraping noise when making u-turn
more than likely a CV joint.
Old Sep 3, 2012 | 06:58 AM
King_cRv's Avatar
Thats the rear diff. Need to replace rear diff fluid!
Old Sep 3, 2012 | 07:05 AM
MonkeyMagic's Avatar
diff fluid in the rear, save something actually rubbing like improperly sized tires. Axles typically click/snap/pop while turning when they are bad.. which doesn't sound like what you're trying to describe.
all three are very different noises. should be immediately recognized by anyone with any sort of experience.
Old Sep 3, 2012 | 12:09 PM
I love to drive
It doesn't sound like tires rubbing and it's definitely not a popping/clicking sound.
Thanks!
Old Sep 5, 2012 | 03:48 PM
DeanHondaPGH's Avatar
If its a howling type of noise, you need to change the rear diff fluid. CV's make a very distinct clicking noise when they go bad.
Posted from Honda-tech.com App for Android
Old Jan 6, 2023 | 12:05 PM
lindylex's Avatar
10 Year Member
As described this is a common failure with the rear differential fluid needing to be replaced. Here is a video of the diagnosis and repair. Hope this helps someone.
"2007 Honda CRV Rear Differential Fluid Change"
Red-Rag-B18
May 7, 2010 09:16 AM
sql_civic
Jun 2, 2009 03:04 PM
SLVRSTN_DC4
Honda S2000
30
May 10, 2008 03:49 PM
MAD ITR 55
Honda Motorcycles
11
Apr 20, 2006 08:31 PM
