Ok ive got a zc in my crx now and i got a question or 2
with my sohc zc in my 91 crx dx right now on dx ecu dx fuel injection dx harness and dx headers what should i be running on street tires? actually all season tires lol.
and what times should i expect if i finish this : stock zc headers, mpfi swap, radials or street tires,2.5 inch catback and si ecu and tranny
can u guys estimate the times on both setups? from your experiences. Thanks in advance- Timmay!!
on a good day, at a good track, you'll be expecting to do mid 16's with the first setup, the second one, you'd probably do low 16's high 15's.
this is so pathetic. if the dx is carbed, run some side draft mikuni's on that mug!!! won't have to see some horrible 16 second time slips then!
dang
how do ppl get low 15 high 14 with sohc zc in oldschool hatch or crx then
Dude. he hasn't even done the MPFI swap yet... which leads me to think he just bolted his DX Intake Manifold and stuff to the ZC... jesus... what a waste of a motor, its not even going to be much faster then the regular DX engine...
Uggh...
Uggh...
Unless you put a buttload of work into a sohc ...dont expect anything super fast. Granted you can build one for the price of a swap..and be pretty fast. But you will be running at 90% of what that engine can handle. There are guys running 10's on sohc. But if you want to get into the low 14s, or lower...expect to blow those things up
-Jake
-Jake
dang
yeah im in seattle wa.. and ive got the entire mpfi swap rdy cept for ecu and resistor box which i will be getting today.. or tomarow.. once i instaled the mpfi and ecu ill tell u guys if its any faster
btw i got zex too which i will be using.. 55 shot that should get me to low 14's right? -_- lol
jdmhondacrx
Mar 16, 2003 11:28 PM
