crx ac condensor noise filter connector
Old Sep 2, 2012 | 01:01 PM
all_motor's Avatar
Default crx ac condensor noise filter connector
anyone know where this connector connects to? for the life of me, I can't where it's supposed to connect to.
Old Sep 2, 2012 | 07:59 PM
Former User's Avatar
Default Re: crx ac condensor noise filter connector
Old Sep 3, 2012 | 01:46 PM
all_motor's Avatar
Thanks, but I have that diagram and I still can't find where the noise filter connector connects to. If anyone has AC in their car, can anyone check it out for me?? It's not the green round connector, but the white rectangular connector.
Old Sep 3, 2012 | 03:46 PM
So you know where the connector is but can't find the noise filter? If so, what color wires does the connector have? It should have 2 Blu/Blk wires and 2 black wires. The noise filter itself is built into the connector. Post pictures.
Old Sep 3, 2012 | 04:30 PM
all_motor's Avatar
If it has "2 Blu/Blk wires and 2 black wires" then Im not sure what that connector is...?
Old Sep 3, 2012 | 04:40 PM
What are the colors of the 2 wires at the bottom of the green connector in the first picture? Is there one or more wires coming out the other end of the green connector? If so, what color are they and do they go to the white connector.
Are the two wires going into the the white connector Blu/Blk?
Does the condenser fan work properly?
Old Sep 3, 2012 | 05:03 PM
all_motor's Avatar
The colors of the 2 wires at the bottom of the green connector in the first picture is blue and black. There is 2 wires coming out of the other end of the green connector. They go into the white connector and they are also blue and black. The condenser fan isn't working. I turned the AC on and let it sit for 5 minutes, nothing.
Old Sep 3, 2012 | 05:08 PM
Tell me if this is correct -- the white connector has 4 wires, all of which are Blu/Blk. Same for the green connector.
Are there any black wires?
Do you see a Blu/Blk wire (power) and a Blk wire (ground) that run to the condenser fan motor?
Do you have a multimeter? I can tell you how to use it to pinpoint the fan problem.
Old Sep 3, 2012 | 05:13 PM
all_motor's Avatar
Yes the white connector has 4 wires, they're all blue and black. I have a multimeter and yes, there are black wires.
Old Sep 3, 2012 | 05:21 PM
Where are the black wires? Are they in the pictures?
Follow the black wire from the condenser fan motor. Where does it lead to?
Old Sep 3, 2012 | 05:30 PM
all_motor's Avatar
The black wire leads to some kind of relay or switch (?), and then to the second green connector in the last picture.
Old Sep 3, 2012 | 05:34 PM
Post a picture - that's probably the noise filter. It's green?
Old Sep 3, 2012 | 05:49 PM
And where does the Blu/Blk power wire from the condenser fan motor run to?
Old Sep 3, 2012 | 05:54 PM
all_motor's Avatar
I think you're right, that's probably the noise filter. I'll post a picture in a bit. Would the white connector have anything to do with the fan not working?
Old Sep 3, 2012 | 05:56 PM
It's unclear at this point, but multimeter tests will reveal the problem. But first I'm trying to get familiar with where the wires run.
Did you do this:
Old Sep 3, 2012 | 06:01 PM
all_motor's Avatar
The blue and black power wire from the condenser fan motor runs to the green connector, then to the noise filter then from the noise filter out comes 4 wires, all blue/black, one set goes to the other green connector, the other set goes to the white connector. There is also one red wire that connects to the compressor.
Old Sep 3, 2012 | 06:10 PM
The blue and black power wire from the condenser fan motor runs to the green connector (GC2?), then to the noise filter then from the noise filter out comes 4 wires, all blue/black, one set goes to the other green connector (GC1?), the other set goes to the white connector. There is also one red wire that connects to the compressor.
1) Let's call the first green connector discussed GC1. It has 4 Blu/Blk wires.
2) How may wires does GC2 have and what are their colors?
3) What color object is the noise filter? The noise filter by definition must have at least 2 black wires. Does any connector of component in that area have 2 black wires?
Old Sep 3, 2012 | 06:19 PM
Power side of fan motor based on your last post:
fan motor --> GC2 --> Noise filter? --> GC1 and white connector
(arrows are blu/blk wires)
Ground side of fan motor based on circuit diagram:
fan motor --> noise filter -->G201 ground
(arrows are blk wires)
Old Sep 3, 2012 | 06:29 PM
all_motor's Avatar
Ok, let's see if this better explains it.
The main long wire wrapped in wire loom in the diagram in your post #2 has a single red wire, 2 blue/black wires to the white connector, from the white connector comes out 2 blue/black wires that goes to the green connector (GC1).
From the AC Condenser Fan is 2 blue/black wires that goes to the green connector (GC2), 2 blue/black wires from the green connector (GC2) goes to the noise filter, from the noise filter goes to the green connector (GC1).
The noise filter is wrapped in some kind rubber cover. The noise filter does have 2 black wires because of the split to GC1 and the white connector.
I hope this makes sense.
Old Sep 3, 2012 | 06:30 PM
all_motor's Avatar
It's like that.
Old Sep 3, 2012 | 06:53 PM
all_motor's Avatar
You know what, Im not sure if this matters, but I think the ac fan that I have is probably from a 88-89. My CRX is a '90, maybe that's why the ac fan doesn't have the white connector? The white connector is from the main wire harness.
Old Sep 3, 2012 | 06:55 PM
all_motor's Avatar
Here are pictures of the noise filter.
Old Sep 4, 2012 | 05:47 PM
sstupid's Avatar
10 Year Member
I have a '91. It's the same as above. Noise filter is bolted to the fan shroud. Wires go from the fan to the green plug, then from the other side of the green plug to the noise filter. From the noise filter, wires go to the relay. If you don't have that rusty brown thing on your fan shroud, you're missing the noise filter. Easily obtainable at any junkyard.
Old Sep 4, 2012 | 10:49 PM
all_motor's Avatar
Do you see/know where that white connector connects to?
Old Sep 5, 2012 | 04:35 PM
sstupid's Avatar
10 Year Member
It plugs into the underside of that brown noise filter.
iplayloudly
Jan 2, 2009 07:21 PM
ottobell22
Oct 16, 2005 04:47 PM
Regular Series
Audio / Security / Video
13
Apr 21, 2003 02:26 PM
