JRSC D16Y8 on a D16Z6....what parts do I need?
I will start off by saying that I dont want to do anything crazy. I was going to throw on a JRSC on my stock D16Z6. I heard it can be run on the stock injectors and fuel pump as long as you dont do too much boost. I figured I would just use the stock 6lb pulley that came with it. Anyways, I found a good deal on a kit for a '96 D16Y8, and heard it would work on my '95 D16Z6. I would just need the 4 rib pulley from the D16Z6 and replace the 3 rib pulley on the SC nose with it. The kit I got came with the SC attached to the throttle body, the bracket with the 2 small pulleys built into it, the large camshaft pulley, and an fmu. Other than the 4 rib pulley, is there anything else I would need for my D16Z6? Thanks!
ksprelude01
Apr 23, 2008 03:02 AM
