Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
04 accord v6 steering pump rattling
Old Sep 2, 2012 | 10:13 AM
leon718's Avatar
Default 04 accord v6 steering pump rattling
Hello all honda experts! There is a rattling noise coming from the from my steering pump. I suspect that the ball bearings are causing it. What will happen if I unscrew the nut (circled) and try to grease the ball bearings? Will the whole thing come apart or is safe for me to attempt this?
Thanks a lot in advance!
Old Sep 2, 2012 | 10:40 AM
Clayton's Avatar
H-T Administrator
25 Year Member
Default Re: 04 accord v6 steering pump rattling
If it's rattling, it likely means the bearing is beyond repair. Try and find a local junkyard with a decent pump, then swap them.
Old Sep 2, 2012 | 03:30 PM
Masster Shake's Avatar
yeah they aren't really designed to be re-greased, once they rattle like that its usually too far gone inside, you'll need to replace it with a new pump
Old Sep 2, 2012 | 10:54 PM
slowcivic2k's Avatar
If the bearing failed it will usually pour oil all over the place. I would remove the belt first and restart the engine to make sure that is actually causing the noise. Then check the all the pulleys for end play and runout.
Post back with your results.
MyGreenHonda
Honda CR-V & Element
Dec 28, 2015 12:25 PM
pentaq
Feb 17, 2015 02:08 AM
Sortamorbid
Mar 6, 2014 02:01 AM
