97 accord heater hoses which one?
Old Sep 1, 2012 | 04:04 PM
BrotherAli's Avatar
Default 97 accord heater hoses which one?
I have been doing some work and just wanted to double check do the two heater hoses go straight from the radiator to the engine or do they cross? Just want to make sure I put the right hose from the radiator onto the right port on the engine.
Im pretty sure they went straight but am now paranoid
Old Sep 1, 2012 | 05:35 PM
GhostAccord's Avatar
Default Re: 97 accord heater hoses which one?
V6 or I4?
On the 4 cylinder the upper rad hose goes to the front of the cylinder head. Then the lower rad hose goes to the thermostat housing.
V6 the upper rad hose goes to the left and the lower rad hose goes on the right (thermostat housing).
Old Sep 1, 2012 | 06:04 PM
BrotherAli's Avatar
Originally Posted by GhostAccord
V6 or I4?
Im getting the small hoses confused they go from the radiator into two brass pipes near eachother. Im 99% that they go in a straight shot to the brass fittings like this:
1:2-3:4 (hoses in a straight shot)
Not like:
1:2-4:3 (hoses would cross over)
But just wanted confirmation before I screw something up.
Old Sep 1, 2012 | 06:31 PM
You must be talking about the trans cooling lines...
If you are looking at the engine the line from the rad on the right goes to the brass fitting on the left. Then the rad hose on the left goes to the brass fitting on the right.
Old Sep 1, 2012 | 08:49 PM
BrotherAli's Avatar
Oh **** thanks alot man. Your one helpful **** appreciate it
Old Sep 2, 2012 | 04:50 AM
You're welcome!
guille595
Mar 29, 2014 07:34 PM
billy hoang
Jan 21, 2007 01:17 PM
thekevin
Nov 6, 2006 09:22 AM
wannakno
Acura TL, RL & ZDX
Sep 15, 2004 06:48 PM
Jaydo
Jul 31, 2004 01:23 PM
