Suspension & Brakes Theory, alignment, spring rates....
Big Brake Upgrade but thats inexpensive?
Old Sep 1, 2012 | 06:47 AM
L1lKraYzi3's Avatar
Default Big Brake Upgrade but thats inexpensive?
I have a 98 DX hatch with a gsr swap,
I still have drums in the rear but I upgraded everything to 99-00 EX in the front.
What Can I do or buy to UPGRADE my calipers rotors and w.e. for BIGGER and Better breaking,
Old Sep 1, 2012 | 06:51 AM
jdmh22eg2's Avatar
Default Re: Big Brake Upgrade but thats inexpensive?
Ok this is what i did to my eg and it stops better than an audi a4 i test drove other day. All goodrich ss lines at wheels,40/40, chase bays brake tuck also ss lines, 1" master, gsr booster, gsr front brakes, gsr rear. Also running REAL axis brake pads. This eg hatch will stop on a dime and give .09 cents back. I am not running drilled or slotted rotors just gsr brembo cores
Old Sep 1, 2012 | 07:14 AM
bgdriver's Avatar
11" mini rotors and type-r calipers
Old Sep 1, 2012 | 08:41 AM
98civdx's Avatar
Master Detailer
https://honda-tech.com/forums/suspension-brakes-54/brakeexperts-brake-chart-thread-civic-brake-upgrades-ef-eg-ek-integras-3044628/
Why do you want to "upgrade" the calipers?
Old Sep 1, 2012 | 09:24 AM
spAdam's Avatar
Loved
Community Favorite
Buy stickier tires.
Old Sep 1, 2012 | 10:42 AM
Libertariat's Avatar
Ek Forever y0!
Originally Posted by spAdam
Buy stickier tires.
This.
Unless you've got DX brakes, even then a fresh set of rotors, autozone ceramics, and a good set of tires will put your face on the dash like you want.
Old Sep 3, 2012 | 08:17 PM
L1lKraYzi3's Avatar
what are SS lines? and how much do they cost?
Old Sep 3, 2012 | 08:19 PM
L1lKraYzi3's Avatar
Originally Posted by 98civdx
https://honda-tech.com/forums/showthread.php?t=3044628
DAMN thx for the info.
Just in case someone piece of **** mustang Brake checks my ***...........I lost my del sol this way...and believe me.. I wasnt riding her ***.
Old Sep 3, 2012 | 08:21 PM
98civdx's Avatar
Master Detailer
All it should need is a good set of pads, rotors, and remember the brakes are only as good as the tires.
I'm doing SI front and rear brakes on my DX, should be more then enough.
Old Sep 3, 2012 | 08:22 PM
bks84's Avatar
Loved
Buy stickier tires.
these is are the trufth
Old Sep 4, 2012 | 06:31 AM
jdmh22eg2's Avatar
Stainless steel (braided) i bought from goodrich (Prob best IMO) i got them on a group buy on another site good time ago. If you do my set and do proper searching (junk yards for master/booster/ and 40/40 prop valve) you can build my same setup for Around 500$ with NEW calipers/ rotors/ pads/ ss goodrich lines. Again imo my set up is all a street car needs. I only need big toe of pressure to stop my car, my brakes work above and beyond my expectations. My chase bays tuck kits was just extra goody to go along with my tuck/shaved bay.
Old Sep 4, 2012 | 08:08 AM
MonkeyMagic's Avatar
the combo of these two are about as good as you could ever need:
Ok this is what i did to my eg and it stops better than an audi a4 i test drove other day. All goodrich ss lines at wheels,40/40, 1" master, gsr booster, gsr front brakes, gsr rear. Also running REAL axis brake pads. This eg hatch will stop on a dime and give .09 cents back. I am not running drilled or slotted rotors just gsr brembo cores
Buy stickier tires.
and then this:
but then:
if someone slams on their brakes, and you rear end them.. you are probably following too closely.
Old Sep 4, 2012 | 09:26 PM
L1lKraYzi3's Avatar
and then this:
but then:
well it was kinda my fault too. I was having caliper problems and they kept losing pressure and leaking...but w.e.
L1lKraYzi3's Avatar
Thx mang
Old Sep 6, 2012 | 01:01 PM
mikekh10a's Avatar
This.
CX too?
Old Sep 6, 2012 | 02:58 PM
98civdx's Avatar
Master Detailer
Yes, CX have the same size brakes
nextgtr
19
Aug 27, 2006 08:38 PM
blueturboteg
Dec 3, 2003 03:27 PM
SIRIUS
16
Nov 29, 2003 04:41 AM
Todd00
12
Jun 7, 2002 07:39 AM
TurboBumblBee
20
Jan 30, 2002 05:06 AM
