97 Civic EX GSR Swap Problems
Old Aug 31, 2012 | 11:06 PM
James4537's Avatar
Default 97 Civic EX GSR Swap Problems
This morning i purchased a 1997 civic ex with a gsr swap in it. the car has a b18c1 in it. After driving for the day i cruised off the freeway shut it off and 2 minutes later i fired it back up to find massive amounts of white smoke coming from the exhaust. it looks like the coolant tank had oil in it and it and could see oil on the inside of my exhaust. I came to the conclusion it is most likely a blown head gasket but does anyone think anything else could be an issue? thanks
Old Sep 1, 2012 | 12:23 AM
EG8_CRUSADER^^'s Avatar
Default Re: 97 Civic EX GSR Swap Problems
sounds like the head gasket to me as well. have you already drained the radiator to check for oil?
Old Sep 1, 2012 | 04:21 AM
Magik8252's Avatar
Do a compression test as well. Also you can remove the spark plugs and check those as well.
Old Sep 1, 2012 | 11:17 AM
James4537's Avatar
Checked everything and it is the head gasket. Disappointing a car I have for a few hours has to break. Oh well
Old Sep 1, 2012 | 11:39 AM
sorry to hear it james, hope you will be able to get behind the wheel again soon
Old Sep 1, 2012 | 03:37 PM
grumblemarc's Avatar
The Grumpiest
How do you miss something like that? Did you inspect it before you bought it? Test drive?
DasShuk
Honda Civic (2001 - 2005)
May 23, 2019 09:14 AM
Looneytunerz
32
May 23, 2012 09:41 PM
RexQ
May 21, 2010 06:28 PM
KillerElfboy
Jun 18, 2006 12:23 AM
bey
Jul 14, 2004 07:05 AM
