is a/c condenser safe to submerge in water?
Old Aug 31, 2012 | 05:26 PM
97accordbuildlx's Avatar
Default is a/c condenser safe to submerge in water?
i didnt know how sensitive the inside of it was where the hoses connect. im trying to clean it.
Old Aug 31, 2012 | 05:58 PM
redyute's Avatar
Default Re: is a/c condenser safe to submerge in water?
It should not be exposed to any kind of moisture,what you can do is if its off the car use a couple cans of brake clean,and then compressed air to dry it off,you wonna make sure clean fluid comes out the other end so you know its properly cleaned.
Old Aug 31, 2012 | 10:10 PM
slowcivic2k's Avatar
Use A/C solvent from a parts store and compressed air. You do not want to put any A/C component near water or a humid environment.
Use a vacuum pump after installation to boil off any cleaner still in the system, and recharge.
Old Aug 31, 2012 | 11:08 PM
okay i wasnt positive glad i checked thankyou
som3on3_10
Jan 6, 2008 07:25 PM
ruffyruff
Feb 27, 2006 06:42 AM
civtic
Jan 7, 2004 09:08 AM
fang
Jun 10, 2002 05:04 PM
typerlover
Sep 15, 2001 01:50 AM
