Semi-built B16a head+ extra's
Old Aug 31, 2012 | 03:05 PM
peep's Avatar
Default Semi-built B16a head+ extra's
Mention you are from honda-tech and I will hook you up on a deal
Have a Complete 1992 OBD1 JDM B16a Head for sale. In great shape!! Has moderate port polishing and pretty fresh valve job!! With a nice set of cams you could have yourself a Type R-esque Head
Note: The head IS NOT mated the the block, It is sitting on the block with a protective gasket in between for storage purposes.
Comes with:
-All hardware
-Complete intake manifold
-Throttle body
-Injectors and fuel rail
-ALLL sensors
-Vtec Silenoid
-Powdercoated Mugen Valve cover
-Dual Valve springs (Intake & Exhaust)
-BLox retainers
-Flat faced Valves
-OBD1 B16a 170hp cams
-Skunk2 Tuner series Adjustable cam gears-- Note: I will only include these if I get the price I want these are $225 alone... pic is below
$600 obo for the COMPLETE cylinder head assembly
I have the entire OBD1 COMPLETE (Sensors hardware and all) B16a engine if you would like a package deal on every thing
But, For extra $$ I have:
-OBD1 Vtec engine wiring harness mint
-The COMPLETE Matching b16a block needs honed....One of the pistons has a hole so I can included a set of PR-4 pistons to throw on the b16 rods to assemble an 8.6:1 boost motor. The crank is still Standard spec, NO spun bearings on crank OR rods
-B series Half shaft
-EG B series mounts from DC chassis
-B series Distubutor needs cap/rotor/coil....Housing/wiring/igniter there (single plug, OBD2?)
$750 Firm for EVERYTHING listed above....
Please do not contact me about my parts and ask "If I'm ever in your area" This is a YOU PICK UP sale.
Lebanon, Or 97355......Can travel to Albany, OR 97322 for ease of access if the deal is right
(54ONE) 971-9379
peep
Northwest (Sales)
Sep 21, 2012 01:21 PM
stockegsix
Northern California (Sales)
Jul 1, 2010 02:08 PM
SR200
Feb 26, 2007 09:07 PM
Pandahatch
Feb 13, 2006 10:43 AM
