Need help/advise on rebuilding BBS RS wheels
Old Aug 31, 2012 | 02:15 PM
G-zus FBBK's Avatar
Default Need help/advise on rebuilding BBS RS wheels
I got this set of 16" BBS rs wheels that I want to build to put on my EK and want some input. I have one pair 16x8 +24 offset lip is 1.5" the other set is 16x7.5 +14 with 1.5" lip also. Now what I want to run is 2"-2.5" lip in the front and 2.5"-3" in the rear. Now this is my first set of 3 piece wheels and would appreciate any info on what face & barrels I should put in the F&R from those who have messed with these wheels on an EK. And yes I plan on rolling the fenders but not looking for an extreme camber. Thanks
Old Sep 7, 2012 | 07:08 AM
Dude_bro's Avatar
Default Re: Need help/advise on rebuilding BBS RS wheels
I believe from my RS build that the Et will drop 6mm for every half inch you go up in lip size. Now you have 2 6inch and 2 5.5inch barrels, and obviously 2 different sets of faces, but it looks like it's only a 3mm Et difference so that's not to bad.
In order to select the correct barrel placement you need to determine a few things, are you doing any fender work, do you want staggered wheels, do you want flush or a little poke and stretch? Then you can figure which Et will work best and choose lip and barrel size.
Personally I would go with the face from the 16x8 and barrel from the
16x7.5 and 2 inch lip in the front. Should work out to 16x8 Et +13 2inch lip.
Back would then be
16x8 +21
add 2.5 lip now 16x9 Et +9
Kind of agressive, you'll need to roll and pull for sure.
Safe play swap barrels, making the 16x7.5 16x8 Et +21 front
Other one is then 16x7.5 Et +18 2inch lip makes 16x8 +12
Old Sep 9, 2012 | 10:03 PM
G-zus FBBK's Avatar
Nice!! Thanks for the info, I think I'm gonna run 2" F - 2.5" R. Don't want too aggressive camber..... Let's see how this works out boosting ��..
PURPLE EK9
Northeast (Sales)
Sep 16, 2011 10:07 AM
omietrice
Oct 22, 2009 04:23 AM
blacc_ej1
Jan 18, 2009 10:56 AM
ej1bmx
Dec 15, 2008 01:07 PM
IdotheSHOCKER
Jul 1, 2002 10:22 PM
