diff between ef and da uca's?
Old Aug 30, 2012 | 07:32 PM
Serdar's Avatar
Default diff between ef and da uca's?
what are the differences between the two, ive jus read that we are not suppose to use da uca's in our cars but has anyone actually compared the two??
Old Aug 30, 2012 | 09:19 PM
crx_arturo's Avatar
Default Re: diff between ef and da uca's?
the da upper control arms aren't centered where the ball joint is. they are off to one side slightly
Old Aug 31, 2012 | 10:59 AM
meda215's Avatar
ef upper control arms are not centered eg's are....I do kno that da's db's n eg's use the same steering knuckle(spindle) so maybe same control arm also.....I had a bad experience with a shop breakin my spindle putting in a bearing....they forgot to take out the snap ring first n my spindle came with crx si spindles which I didn't kno
I tryed just about every spindle. lol
Posted from Honda-tech.com App for Android
Old Aug 31, 2012 | 11:21 AM
4drEF's Avatar
Keyboard Humorist
Not sure about the knuckle, but for certain the UCA between EG and DA are different.
They won't even bolt in if you try to swap.
Caster gets messed up when swapping the DA UCAs into an ED/EF
sasinorm01
Jul 12, 2016 08:42 AM
Jared
Suspension & Brakes
Jun 28, 2007 04:40 PM
EF'n Stig
Aug 6, 2006 06:56 PM
EPrepCivic
May 19, 2005 07:30 AM
