AFI Turbo Kits available for order
B-Series Ramhorn Turbo Street Kit
*AFI's Street turbo kit is perfect for the enthusiast who wants to take their street/strip car to the next level without breaking the bank! This kit uses the Ramhorn manifold and comes with a 57 trim turbo (450hp max)along with all the necessary hardware to bolt this kit together. Call for more options!
Packages starting at $2,699
B-Series A/C Turbro Kit
*AFI is now offering a B-Series turbo kit for those of you that are wanting to keep your A/C setup for those hot days during the summer and still allows you to make plenty of power! This kit includes a vband housing turbo from Precision (which model depends on the power you want), and a Turbo Smart Comp 40 Gate.
Turbo options:
PTE5558 (570hp)
PTE5858 (605hp)
PTE6262 (680hp)
PTE6266 (700hp)
Packages starting from $3,999
B-Series Forward Facing Mount Race Turbo Kit
*AFI is proud to present the track proven performance of our Forward Facing Race Kit! This kit comes standard with all the necessary hardware, and the Precision 6266 Turbo with a 45mm wastegate vband housing. If you want you can always go bigger! There are plenty of options to choose fro.
Kits starting at $4,499
+$285 Divided 40mm gates
+$400 Divided 45mm gates
+$500 For ball bearing 6266
B-Series Bottom Mount Race Turbo Kit
*AFI is proud to present the track proven performance of our Bottom Mount Race Kit! This kit comes standard with all the necessary hardware, and the Precision 6266 Turbo with a 45mm wastegate vband housing. If you want you can always go bigger! There are plenty of options to choose fro.
B-Series Top mount Race Turbo Kit
*AFI is proud to present the track proven performance of the Top Mount Race Kit! This kit comes standard with all the necessary hardware, and the Precision 6266 Turbo with a 45mm wastegate vband housing. If you want you can always go bigger! There are plenty of options to choose from
K-Series Swap Kit
*For those of your guys rockin’ the K-Series motors….heres a turbo kit just for you guys. AFI introduces the turbo kit for the K20/K24motors. This kit comes standard with all the necessary hardware, and the Precision 6266 Turbo with a 45mm wastegate vband housing. If you want you can always go bigger! There are plenty of options to choose from.
Packages starting at $4,499
S2000 Street/Race Turbo Kit
*Here is our popular and track proven turbo package for the S2000. We have seen this kit put down 700+HP without breaking a sweat!! Our kit comes with the impressive Precision 6266 turbo with the 45mm waste gate and all the necessary hardware to slap this kit on. You will not be disappointed with our kit! you have plenty options to play with when it comes to turbo sizes, so if you wanna go bigger then we can help you in any direction you want to go.
Packages starting at $4,799
Turbo options:
PTE5558 (570hp)
PTE5858 (605hp)
PTE6262 (680hp)
PTE6266 (700hp)
K-Series Swap Kit
