Has anyone ever swapped the three popular vtec heads to see exactly hp differences?
Old Aug 30, 2012 | 06:09 PM
Deetz's Avatar
Crazy Honda Guy
Default Has anyone ever swapped the three popular vtec heads to see exactly hp differences?
I have all three heads sitting around in my garage. The rsx k20a2 type s head complete, a k24a2 tsx head comlpete, and a K20z3 civic Si head complete.
I wonder if anyone has done an actual swap on a block with each head to really see what performance advantage there is between each....all other things being equal.
Feedback would be awesome!!! thanks in advance
Old Aug 30, 2012 | 06:50 PM
xenocron's Avatar
Default Re: Has anyone ever swapped the three popular vtec heads to see exactly hp difference
The heads are basically the same...its the cams that are different, at least between the A2 and Z1 and the Z3.
The TSX cams are identical to one of those heads i believe, im just not certain which one.
Old Aug 30, 2012 | 06:55 PM
erbavour's Avatar
negative. k20z3/z1/a2 all day 50 degrees or RBB's 30 degrees of advancing fun.
Old Sep 4, 2012 | 10:37 AM
Gearspeed-Performance's Avatar
The A2 (PRC/B) head is the better one, the TSX (RBB) head is very similar to the Civic Si (RBC) head in flow characteristics and are both good heads in their own right, however the A2 flows slightly better IIRC.
Old Sep 4, 2012 | 03:38 PM
Deetz's Avatar
Crazy Honda Guy
This is great information, thank you
Old Oct 4, 2012 | 11:29 AM
6SPD_EK's Avatar
actually RSP>PRB>RBC>RBB
credit goes to luke from 4piston for this
dyno test RSP ('08 type r) VS RBB (tsx) on a 12.5cr k24, IPS KME, RRC, DTR header, 60mm exh (original graphs can ge seen here) http://www.k20a.org/forum/showthread.php?t=107797
actually z3 & a2 share the same exhaust cam
z1 & type r are the same (some with a slightly different centerline)
z1 intake & '06+ tsx share the same secondary vtec lobe
'04-05 tsx & 06+ tsx share the same exhaust cam
bigsnorlax
Apr 28, 2009 11:00 AM
jcruz169
Jul 1, 2007 12:13 AM
chris2000
17
Dec 7, 2006 12:50 PM
Top Ramen
Acura TSX
14
Sep 23, 2004 05:35 PM
AlienKrOZ
Jul 22, 2004 05:28 AM
