crome pro o2 voltage fluctuation and p72 wont log with j12 removed
Old Aug 29, 2012 | 08:46 PM
cxserver's Avatar
Default crome pro o2 voltage fluctuation and p72 wont log with j12 removed
Wideband reads steady but afr in crome pro 1.6.5 the o2 voltage fluctuates from 0.5-1.6 with afr going back and fourth by a full point. Also batterie voltage moves around a small amount.
92 civic dx
Inovative mtx-l wideband
Powered by a25 yellow/black stripe wire on ecu
Grounded on chassis
O2 wire hooked to d14 white ecu wire
My p06 will datalog fine but my chipped p72 will not. It has j12 removed and a dataloging header. Also has another spot jumped with a blue wire.
Old Sep 8, 2012 | 05:58 PM
cxserver's Avatar
Default Re: crome pro o2 voltage fluctuation and p72 wont log with j12 removed
Anyone? I read that only the ground wire would cause the o2 fluctuation in crome, dosn't make a difference where i ground it though.
Any ideas about the chipped p72 not logging but the p06 does?
what wires would work safely in the fuse box for power? (92 civic)
spoonzdelsol
Oct 4, 2005 12:40 PM
H23vtecEG
Apr 4, 2003 08:12 AM
Tony the Tiger
Oct 23, 2001 10:55 PM
