Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Check Engine Light Flashes Randomly
Old Aug 29, 2012 | 08:25 PM
D17 Fiend's Avatar
Icon6 Check Engine Light Flashes Randomly
I have A 2003 Honda Civic Ex with a D17A2 motor. When I start the car the idle is fine and car has full power whether at idle or driving. The check engine light has been on since i bought the car the only thing is it turns off and back on randomly and then after a while of it doing that the ECU goes into limp mode can anyone explain to me what is happening.
Old Aug 29, 2012 | 10:17 PM
It Wasn't Me's Avatar
Default Re: Check Engine Light Flashes Randomly
Find out why the MIL has been coming on by scanning the car. You can do it yourself if you have a scanner, or you can take the car to an auto parts store and have them do it for free. Many places will. I don't advise taking it to the dealer just to have it scanned.
After you scan it, post the code(s) here.
Old Aug 30, 2012 | 03:18 PM
D17 Fiend's Avatar
Ok I will I did it before and the codes for bank 1 and bank 2 came up which I thought was the O2 Sensors but I will get the most recent codes and post them.
Old Aug 30, 2012 | 03:27 PM
If the light is literally "flashing" when this happens, it's due to a misfire which can be caused by a number of things. Bad fuel or insufficient fuel pressure, incorrect valve lash, fouled or incorrect spark plugs, etc. etc. The list goes on.
But, yeah, find out what codes they are and post them here. That'll help us give you some advice as to what you can do to fix it.
Old Sep 6, 2012 | 11:48 AM
coltonjamesb's Avatar
mine has came on and went back out and also lost power suddenly im told it is my catalytic converter so i am replaceing it with racing headers aswell as a highflow hopefully i dont mess it up :/ lol
good luck my man
Old Sep 9, 2012 | 12:09 PM
zozzancs's Avatar
Buy some obd2 scanner on ebay, and connect to your smartphone via bluetooth. Use torque pro and scan the ecu fault codes.
Ando69
Jul 16, 2015 10:57 AM
Sick CiviC EX
Oct 18, 2009 03:13 PM
lanojp1
Nov 25, 2004 08:53 PM
sykotic
Nov 19, 2004 11:01 AM
champwhiteitr
Mar 17, 2004 03:39 PM
