what kind of gas milage do you get
Old Aug 29, 2012 | 03:49 PM
jchope's Avatar
Default what kind of gas milage do you get
like the title says i wana see what kind of gas millage you guys get to a tank
Old Aug 29, 2012 | 03:57 PM
zrickety's Avatar
Default Re: what kind of gas milage do you get
There are already 100 threads about this. My old dx got 47mpg, my B16 Si gets 30-32mpg. About 300 miles per tank, but that is a bad measurement.
Old Aug 29, 2012 | 04:49 PM
KINGVEM^^ED6's Avatar
350~
Y7 mpfi dx trans
Old Aug 29, 2012 | 05:11 PM
crvtectim's Avatar
8mpg
Old Aug 29, 2012 | 05:36 PM
civicsiguy21's Avatar
About 47 is right
Old Aug 29, 2012 | 05:42 PM
gutted-dx's Avatar
320mptank to a 93 civic DX
B20vtec-B16 trans
Old Aug 29, 2012 | 07:34 PM
t-town_ep's Avatar
I get 44.8mpg in my std hatch
d15b2, dpfi, 5spd, tranny, 13in steelies
Old Aug 29, 2012 | 07:47 PM
DumpdEJ6's Avatar
I like the tuna here
42mpg if I don't get on it much. 1989 CRX DX w/DOHC ZC.
Old Aug 29, 2012 | 07:54 PM
Einhander276's Avatar
22 city 32 highway LS/LS tranny 91 Civic Si
Old Aug 29, 2012 | 08:07 PM
hoga113's Avatar
B16A3 Y1 tranny, 30 mpg
Old Aug 29, 2012 | 11:15 PM
Vagitarian's Avatar
Dohc Zc, zc trans, mostly city, 31 mpg
Old Aug 30, 2012 | 08:47 AM
91 EF DX's Avatar
d15b2 dpfi auto trans wagon. 28-34 mpg depends on how i drive and thats including a lot of city driving.
Old Aug 30, 2012 | 08:57 AM
rico58204's Avatar
90 sedan
w/a6=33mpg avg
w/dohczc=35mpg avg
w/b16a3=38mpg avg
Old Aug 30, 2012 | 10:51 AM
DumpdEJ6's Avatar
What do you have done to your ZC that you get 10mpg less than I do? I know it could just be driving habits, I usually only rip through the gears at WOT maybe once or twice per tank, the rest is spent 50/50 highway/city. I've only got an air intake and 2" exhaust on mine.
Old Aug 30, 2012 | 08:43 PM
cdmed6si's Avatar
91 dx d16a6 36 city 40+ hwy best recorded 57.9
Old Aug 30, 2012 | 10:10 PM
tonylovesjdmEF9's Avatar
i think from last time i checked i get 36 or 34 mpg combined but i do 4k all day thanks to my si trans and me smashing on it
Old Aug 30, 2012 | 10:13 PM
ElCivic89's Avatar
14 cents a mile over here
Old Aug 31, 2012 | 12:54 AM
DCRB's Avatar
i get crappy gas mileage for a honda, about 250 miles per 30 bux of premium. if i milk it from full full to fumes i can get about 320. a6/z6 highish compression 90 ex transmission. i should add i don't really see a difference in mileage between shifting at 3k rpms in every gear vs. redline in every gear
Old Aug 31, 2012 | 02:12 AM
tast2s's Avatar
my dx doesn't nearly get the mil its so sopposes to get.. anyone know what I can do to get good mil? dpfi 4spd dx d15 wit ac
Old Aug 31, 2012 | 07:12 AM
LoveDeezNutz's Avatar
My 91 DX got about 37
My 88 dohc zc I am only getting about 27 average
Both 100% stock
City I guess.
I shift when i hit 3k, and my normal driving speed is typically 2.1k in 4th. I thought I was being conservative by shifting at those rpms. Have no clue why my gas mileage is so bad.
Old Aug 31, 2012 | 08:56 AM
Scott91Hatch's Avatar
Stock D15b1 with MPFI, 5-speed si transmission, Injen CAI, Magnaflow exhaust, and 205/55/R15 tires and I typically average between 37-42 mpg. Doing the speed limit and driving conservatively on the interstate for extended periods I have averaged as high as 49.
Mostly it comes down to efficiency and driving habits...keep your car tuned up and running properly (clean air filter, new fuel filter, plugs, wires, check timing) and maintain suspension that can rob you of power by keeping the alignment withing specs, replacing worn bushings, making sure that you brakes aren't dragging, etc. I spent a ton of money making my car efficient and reliable. If it's a beater or if you plan on doing a swap then I wouldn't put money into it to improve the fuel economy because you could spend a thousand bucks just to get 5-10 more mpg and it would take a while to recover the investment.
Old Aug 31, 2012 | 09:37 AM
89ef9-87starion's Avatar
about 30-31 b16a type r cams gsr tranny. in si hatch
Old Aug 31, 2012 | 09:39 PM
90civicstdgold's Avatar
91 CRX, 700+hp.... about 20mpg
Never actually ran a full tank through it on pump gas. (Not on pump anymore)
DD: 93 civic sedan, stock block, hx trans.... usually 40-42mpg
Old Sep 1, 2012 | 03:34 AM
So yesterday I pulled 399 out of one tank
Combined highway.n city
Old Sep 1, 2012 | 06:12 AM
91turbosohc's Avatar
30 mpg on y8/b2 all city miles. I had it tuned on 87 for some reason it likes premium instead.
