heat shield
Old Aug 29, 2012 | 12:55 PM
Cameron k.'s Avatar
Default heat shield
how do i get my heat shield off of the d16z6? i saw the bolts, but theres a wire running to it, not sure what it is but how do i get it off?
Old Aug 29, 2012 | 01:04 PM
Solster's Avatar
Default Re: heat shield
remove the 3~4 bolt holing the heat shield to the exhaust manifold
fallow wire of the O2 sensor to the gray 4 wire clip to the left of the manifold
unclip the connector from the mounting bracket
unplug the connector from the harness
pull back heat shild
pass wire throught the hole in heatshild
faling this buy the shop manual for your car (should be done if the first 4 hours of buying the car) look up removing the exhaust mani and fallow direction.
failing that sell car and ride the bus.
Old Aug 29, 2012 | 01:15 PM
Cameron k.'s Avatar
i will one day but for now could you tell me how to get the clip off? i dont want to break it.
Old Aug 29, 2012 | 01:36 PM
Solster's Avatar
bottom side of the connector Sensor side is a plastic tang squeze and slide it off.
Old Aug 29, 2012 | 01:46 PM
Cameron k.'s Avatar
thank you i got it off, the bolts are rusted, any ideas on how to get them off?
Old Aug 29, 2012 | 01:52 PM
Kohen's Avatar
PB Blaster. If you don't have that, WD40. Let it soak.
Deanshirt90
Sep 25, 2012 02:26 PM
Deanshirt90
Engine Management and Tuning
Sep 25, 2012 01:03 PM
luckster
May 17, 2008 09:24 AM
CRVRX
50
Feb 28, 2006 04:55 AM
neilff
Jun 18, 2003 04:56 AM
