CRX SI STARTING PROBLEM
Old Aug 28, 2012 | 07:24 PM
dailympg35's Avatar
Icon2 CRX SI STARTING PROBLEM
I have a 1989 Honda crx si, I bought it with the cylinder head off and various missing parts. It was sitting in a guys garage for 4 years. I put everything back together but I had to relocate the battery to the back to install my aftermarket intake. So I don't know if my relocate started the problem or not since I never ran it with it under the hood.
Anyway, my problem is if its real hot outside or I've been driving a while and I go to start it, it will just crank. The check engine light stays on and the fuel pump doesn't kick on. After it sits for a bit and I turn the key off and on a bunch of times the fuel pump kicks on and the check engine light goes off then it starts no problem. I thought it might be a ground issue so I ran a ground cable from the battery back to the front where the original ground was. It seems like that helped for a while but now its doing it again.
Any ideas?
Old Aug 28, 2012 | 07:59 PM
Former User's Avatar
Default Re: CRX SI STARTING PROBLEM
Start by resoldering the main relay and cleaning/tightening the g101 ground on the thermostat housing.
J . K .
Oct 28, 2014 07:48 PM
scottmog
Jun 18, 2009 07:21 AM
cfwthb_94
10
Dec 18, 2006 07:35 PM
suspirocrx
26
May 30, 2006 04:15 PM
LODIDODI
Jan 3, 2006 05:37 PM
