$231 for on OXYGEN SENSOR!!!!!
Old Oct 16, 2002 | 12:02 PM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
Default $231 for on OXYGEN SENSOR!!!!!
I went to the acura dealership today to check on an 02 sensor for my b18 since it didnt come with one. Well the guy comes back and tells me that a new 02 sensor for a 92 GS is $231. Ive been told that you can get them for around $80 or $85. I want to know where i can get this deal at...i dont really want to spend that much on an 02 sensor. Where can i get one for cheaper? Thanks.
Sean
Old Oct 16, 2002 | 12:08 PM
jc836's Avatar
Default Re: $231 for on OXYGEN SENSOR!!!!! (sCeRaXn)
There is an online source and NAPA also has them. BUT, be warned that the OEM Honda sensors are the best for our cars-period. THey last longer and will not throw any codes. As to the price, you need to join the Honda-Acura Club so that you can get a discount at your favorite particpating ddealer parts department. I paid $150 for an O2 sensor for my D16a6 and it has a list of over $200.
Old Oct 16, 2002 | 12:18 PM
markedOO1's Avatar
yup...those heated o2 sensors are defintely pricey
Old Oct 16, 2002 | 12:39 PM
Speed PHreak's Avatar
Default Re: $231 for on OXYGEN SENSOR!!!!! (marked001)
sigh....when will people learn that an O2 sensor is an O2 sensor. 231 dollars for an O2 sensor!!!? Thats ludacris, a 5-wire NTK WIDEBAND O2 costs that much. Why the hell would your regular run of the mill heated NARROWBAND 02 sensor cost that much??? Simple the dealer wants money, goto NAPA or Autozone and pick one up. A Bosch replacement O2 will work just fine.
Old Oct 16, 2002 | 12:40 PM
BlackCRX's Avatar
Sean
the oem tents to respond alot faster then the aftermarket ones
from what i have heard the bosch ones are as close to oem as you can get
Old Oct 16, 2002 | 12:44 PM
altoid's Avatar
Default Re: $231 for on OXYGEN SENSOR!!!!! (BlackCRX)
i get mine at cost, one for my d16a6 was $90, if you guys want i can ask around and see if i can get them. Honda OEM too
[Modified by altoid, 12:32 AM 10/17/2002]
Old Oct 16, 2002 | 01:55 PM
Doodoo's Avatar
go to http://www.oxygensensors.com $89.99 for stock 'style' 4 wire.
I bought mine from there about a year ago. Looks and works great, alot better than the bosch ones I bought. Don't get me wrong though the bosch ones do work.
Old Oct 16, 2002 | 03:56 PM
ijjz's Avatar
Default Re: $231 for on OXYGEN SENSOR!!!!! (Doodoo)
Autozone sells a bosch one for $35
Old Oct 16, 2002 | 04:35 PM
tunedcivic's Avatar
Default Re: $231 for on OXYGEN SENSOR!!!!! (ijjz)
how much is an o2 simulaor???
Old Oct 16, 2002 | 05:28 PM
technine's Avatar
for above. Man, you guys should shop around. But the heated O2's cost a grip.
[Modified by technine, 2:28 AM 10/17/2002]
Old Oct 16, 2002 | 05:48 PM
dustin's Avatar
Default Re: $231 for on OXYGEN SENSOR!!!!! (technine)
I bought a headed 4wire bosch universal sensor for under $50 from http://www.thepartsbin.com.
The impedence across the heater circuit is wrong, so I had to put a resistor inline to get rid of the code 41. Works fine.
Dustin
Old Oct 16, 2002 | 07:03 PM
USDM 4G VTEC's Avatar
Bosh 1 wire Universal O2 sensor... works like a charm... my performance shop has them on 4G and even Type R's(not the 1 wire of course) and they are good...dyno proven!
Old Oct 16, 2002 | 07:44 PM
cbrman's Avatar
autozone will sell 2 that will work for you.
A generic 4 wire o2 sensor that wont have the plastic connector on the end.~35-50
And an oem replacement one with the plastic connector for ~90 bucks. At least that was my two options when i needed to replace my damaged O2 sensor on my 98 y8 motor. My dad picked mine up for me, and he got the one with the connector for 90. Oh well that pretty plastic connector was worth the extra 55-40 bucks.
Old Oct 16, 2002 | 09:50 PM
MaxED9's Avatar
Default Re: $231 for on OXYGEN SENSOR!!!!! (cbrman)
try a junkyard... ive never had a problem with them... and for 2 bucks each i can buy like 5 of em... just in case...
Old Oct 17, 2002 | 02:37 AM
zelifcam's Avatar
I bought an O2 sensor for my D16Z6, heated, from NAPA. It was about $75, but it is a Denso! I think the OE sensor was Denso too (at least that was what was in there), so I'm happy.
Old Oct 17, 2002 | 02:46 AM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Re: $231 for on OXYGEN SENSOR!!!!! (zelifcam)
BOSCH
these are exactly the same ones dealers use cuz bosch makes sensor for honda toyota acura
etc
they are basically the same and cheap
around 30-60
Old Oct 17, 2002 | 04:40 AM
Superhatch's Avatar
Default Re: $231 for on OXYGEN SENSOR!!!!! (MugenHonda)
I just bought a bosch from Checker auto. 42.99. I installed it, reset the ecu..code went away. But on my way to work this morning, guess what. o2 sensor code is back again..and car started hesitating. Ive heard you get what you pay for with the bosch plugs. Obviously I did
-Jake
Old Oct 17, 2002 | 06:31 AM
xci_ed6's Avatar
Default Re: $231 for on OXYGEN SENSOR!!!!! (SuperHatch)
Could also be that there is something else wrong with you car causing the O2 sensor to fail. I have had my car throw an O2 code before, but shutting it off and turning it back on made it go away.
-Dustin
Old Oct 17, 2002 | 07:03 AM
Superhatch's Avatar
Default Re: $231 for on OXYGEN SENSOR!!!!! (Autocratic_1st_Gen)
Thats what I was thinking...because if I reset the ecu it goes away. when thats gone I get a code 20. Sensor failure. Not specific to which one though.
-Jake
[Modified by SuperHatch, 10:42 AM 10/17/2002]
Old Oct 17, 2002 | 08:47 AM
serious's Avatar
http://www.acuraautomotiveparts.net
they have oem ones for $166.
Old Oct 17, 2002 | 12:58 PM
DRFlickner's Avatar
I used the $40 Autozone one. No engine codes, passed smog with it in there too.
Old Oct 17, 2002 | 02:46 PM
Urban Business
Guest
Posts: n/a
hparts.com for oem parts. other wise get the cheapest pile of ship single wire from any parts store, splice directly into harness. they WILL **** up in a few weeks. i keep going thru bosch ones like toilet paper. longest i had one work for was 4 months. least was 2 days. thank god for lifetime warrenty
Old Oct 17, 2002 | 03:32 PM
Monty's Avatar
Check prices on the LS ones. Alot of the time they are the same as GS but just a higher price. I can get 20% off at honda if you want me to see how much they are up here in the hills.
Old Oct 17, 2002 | 03:39 PM
02WRX's Avatar
Default Re: $231 for on OXYGEN SENSOR!!!!! (Monty)
Use Bosch. That's what the local dealership mechanic recommended. That's what I'm using...
Eric
Old Oct 17, 2002 | 06:00 PM
fixhondas's Avatar
If you can get a DENSO O2 with the proper heater resistance for $75 I would definitely go for it. Most of Hondas O2 sensors are made by Denso.
