What can one tuner do differently than the other?
jdm sir2 motor
310lph fp
550cc injectors
turbo = garett t3 60/.63
blox manifold
custom dp
no name external wg
cx racing ic + bov
230whp @ 8psi (almost 7 by redline)
was expecting numbers closer to 250-260
310lph fp
550cc injectors
blox manifold
custom dp
no name external wg
cx racing ic + bov
depends on what kind of tuning the tuner will do and what dyno is used. one tuner will net you peak hp and others will focus more on part throttle tuning. your number sounds good! at 230whp on a roller dyno your numbers are close to 280-290hp on a dyna pack hub dyno
Tuners majority know the AFR's to shoot for and typically know what type of ignition to shoot for. There's alot that goes into a tuning a car, some tuners like a leaner AFR some like a richer, depending on experiences they've had with past setups and with past customers. Some tuners read plugs, some dont..there's alot of different ways to tune a car.
Another thing to take into consideration is all setups are different. Take it to the track and see what it traps. I recently tuned a b16a2 on 8psi, made alittle over 200whp, stock cat, stock everything else except injectors and the greddy kit. Ran good, idled good, and provided good useable street power.
There's alot you can do to make more power on your setup though, Better cams, better manifold, open DP probably would add a ton of power.
i honestly despise most tuners with shops and dynos cuz just like someone said they either focus for peak hp or part throttle. and too be honest i would prefer part throttle over peak power. its either ur car is fast when your full throttle and pinges, bogs, idles like ****, and just plain pisses you off or it will run smoothly but will bog in higher rpms, and on top of that they never tune for fuel mileage.
you gota remember unless its a full purpose car, that your gonna be driving this car everyday or at least i do like a 100miles and that fuel mileage is extremely important.
so thats why you invest in a aem uego wideband gauge, mount it on your steering wheel column. spend the money for hondata and do lots of research and trial and error and you will surely learn to tune your own car and in the end save a boat load of money
Who is Mr Robot?
is it a straight t3? based on your post i'd say so... since a t04e won't have boost dropoff whatsoever.
so thats about right for a straight 60 trim t3... you'll only see 300hp max out of that turbo so your numbers are right inline with what other people make on that turbo
The fp i originally brought didnt fit and the shop had one laying around
This was in a dynapack
Took it to the track tonight. Did 14.2 at 103mph. 1st n 2nd gear is spin city(only did a single run)
I have an aem wideband and its tuned on s100
Anyways if you guys are saying its normal i guess its fine till i up
The psi :D
dam dude and how much did you spend for this tuning?!
The psi :D
Who is Mr Robot?
don't expect much, that turbo will only flow enough for 300 crank hp... so you're about at its limit anyways
It was already said. If that's a straight T3 those numbers are about right. Saw a type r on a similar turbo put down 215 @ 8 psi on a dynojet. If you want more power your gonna have to run more boost. Dont get Hung up on the psi. If you want 250 then go for it. With a good tuner this shouldnt be a problem. Also any good tuner should make sure you have good partial throttle.....
*shrug*.. sometimes its over people's head...
sometimes people just dont need to know how much work actually goes into it.
Find someone with a 250whp+ B16 using a t3/t4 and examine his times (aka race him). Chances are your 230whp t3 will rip apart someone with a 250whp 57trim. If not there's something wrong with your parts, not your tuner.
Side note, my d16 coupe has nearly the same turbo, 8:1 compression, and a dx trans - I did 14.1@102 with 6yr old street tires. I'd vote there's something fishy about your setup.
Who is Mr Robot?
his setup is more of a street oriented setup... I bet the straight t3 is a fun street turbo... doesn't make a ton of power but I bet it's got a really decent powerband.
Reading some of these replies just makes my shake my head lol
Just to clarify, when I said any good tuners should make sure you should have good partial throttle I did not mean thats all he should worry about.
