Kill Switch Help!
I have installed my light up 3 pin switch for kill switch.
1. Ground (Connected)
2. Accessories
3. Power (Connected with 20a fuse holder)
The light work's when turned on. Now. . .
To kill a fuel pump there is a yellow wire with a black stripe.
Now before i cut anything i wanna know where am i connecting the Accessories switch to? Normally people only use 2 pin switch which is simpler but i would like to have a switch to show the kill switch is on.
(PS i do have a bosch relay 5 pin if thats what i need)
2. Accessories
I dont know what the heck youre doing, but its to complicated.
Pick a spot in your car to tap into the fuel pump ground, (starts under the rear seat area) And simply put a 2 prong switch THAT DOESNT LIGHT UP in there, run extra wire if you want to run the switch to a different area of the car..
so easy
so easy
SigmaOmega
Jul 17, 2005 06:55 PM
