High Compression OEM LS/VTEC +++
I am selling a project that I have been putting together for the last few months. Brand new motor with ZERO miles on it, and it's freshly rebuilt. This is a high compression OEM LS/VTEC build. This motor should be a lot of fun and pretty torquey. This is the parts list and machine work done to the motor. I have a lot of money and time invested into this motor.
Machine Work:
Hot Tank
Hone
Polishing Crank
Valve Job
Recondition Rods
Recondition Pistons
Hone Rods
Deck Head
Valve Seals
Install Pistons on Rods
Head:
GSR Head
GSR Throttle Body & Sensors
01 ITR Cams
OEM Cam Seals
Type R Dual Valve Springs
FelPro Head Gasket
GSR Intake Manifold
OBD1 Uncut VTEC Harness
Shaved/Painted Valve Cover w/ Wrinkle Red Paint
450cc DSM Injectors
Fuel Rail
ARP Head Studs
Block:
LS Rods
LS Block
ARP Rod Bolts
P30 Pistons
LS Crank
OEM GSR Water Pump
OEM GSR Oil Pump
OEM GSR Timing Belt
OEM Rear Main Seal
NPR Piston Rings
King Rod Bearings
King Main Bearings
King Thrust Washers
Gasket Kit
Fel-Pro Head Gasket
Alternator Belt
Alternator
Stage 3 Competition Clutch
LS Flywheel
1/2 Shaft
OEM Honda Axle
LS/VTEC Kit:
Golden Eagle Dowel Pins
Oil Sandwich Plate
Oil Fittings
Oil Line
I don't have the intake manifold and a couple small things done yet, but it will be complete by the end of this week. Text me with any questions you have at 719-238-6833.
Machine Work:
Hot Tank
Hone
Polishing Crank
Valve Job
Recondition Rods
Recondition Pistons
Hone Rods
Deck Head
Valve Seals
Head:
GSR Head
01 ITR Cams
OEM Cam Seals
FelPro Head Gasket
GSR Intake Manifold
450cc DSM Injectors
Fuel Rail
ARP Head Studs
Block:
LS Rods
LS Block
ARP Rod Bolts
P30 Pistons
LS Crank
OEM GSR Water Pump
OEM GSR Oil Pump
OEM GSR Timing Belt
OEM Rear Main Seal
NPR Piston Rings
King Rod Bearings
King Main Bearings
King Thrust Washers
Gasket Kit
Fel-Pro Head Gasket
Alternator Belt
Alternator
LS Flywheel
1/2 Shaft
OEM Honda Axle
LS/VTEC Kit:
Oil Sandwich Plate
Oil Fittings
Oil Line
