crx injector problem
i have a 1991 crx hf .i just changed the dash harness and engine harness to a si.my car start but then turn right back i took the injectors out with the fuel rail and the injectors spray on time but wont keep spraying when i keep cranking it .i changed the ecu the main relay,and resistor box. Cracked the line up at the fuel rail and there is fuel there.when i spray starter fuel in it it runs .heeeellllppp meeeeee
littleprophet13
Feb 15, 2010 07:47 PM
