Few issues with my 94 accord
Old Aug 26, 2012 | 11:57 PM
94AccordSasha's Avatar
Default Few issues with my 94 accord
So the first issue that i am trying to figure out is at around 60mph the car wobbles but above or below that it does not also sort of wobbles when bracking but not nearly as bad as when it wobbles at 60. Any thoughts? i know that the wheels being out of balance could affect highway speeds but i was just wondering if it could be anything else.
Also just recently my ABS light will turn on after maybe 2 or 3 minutes of the car running even if i am not moving and fluids and pressure seam to be in good order it used to come on once in awhile and go away randomly so im not sure if its a wheel sensor or something worse.
Id really appreciate any feedback also will have questions on an H22 swap here in a couple months is there a thread for maybe a list of what you all need i plan on ordering an engine of Hmotors with a complete conversion comes with basically everything but again all feedback is appreciated thanks!
Old Aug 27, 2012 | 12:50 AM
Dioxine's Avatar
Default Re: Few issues with my 94 accord
1st off Unbalanced tires is going to the cause of the shaking at highway speeds no questions really.
2nd Warped rotors on the shaking while braking, almost no question about it.
3rd ABS is a tricky thing can't really help you there
4th There are plenty of threads about the h22 swap, do your homework, do more, then when you think you know everything you need to, do some more homework, then give it a shot.
Old Aug 27, 2012 | 01:07 PM
Ok lol thanks im new the the accords i know a civic inside and out though lol.
dmlagrange
Sep 2, 2008 07:40 PM
98accordv6green
Nov 17, 2007 11:55 AM
jaader
Sep 13, 2003 07:39 PM
