Suspension & Brakes Theory, alignment, spring rates....
ground control suspension questions.
Old Aug 26, 2012 | 08:43 PM
muddmonky's Avatar
Icon2 ground control suspension questions.
have a 98 civic dx coupe.
i have 205-40zr17 tires which equate to the same as stock height, and the wheels i beleive have a +40 offset. i want to lower the car enough to tuck the tires a little but i dont realy think i want it crazy like flush with the bead of the wheel but i want like half an inch to 2in of tire under the fender.
1) will the coilovers go that low
2) what spring rate would be good for that height as a daily driver. go-kart feel is cool with me but i dont want to bite my tongue on bumps or brake my neck ya know.
the standard ones i was told where 380 FR/280 REAR but when i googled what most ppl where running they went stiffer in the rear than in the front and they where 380-500 sping rate.
Old Aug 28, 2012 | 03:24 PM
muddmonky's Avatar
Default Re: ground control suspension questions.
ya i dont think id go quite that low but i definatly want a little tire under the fender.
yall think 450 front 550 rear would work that seams to be a realy realy comon setup from what iv been reading on a lot of sights.
but theres still a few that say 550-600 minimum front and rear but i dont know if there extremists or trying to be funny or if its true or not.
Old Aug 28, 2012 | 04:30 PM
98civdx's Avatar
Master Detailer
550F/450R should be plenty stiff.
Old Aug 29, 2012 | 10:17 AM
Libertariat's Avatar
Ek Forever y0!
Indeed, higher rates in the rear promotes major turn-in and oversteer you might not be comfortable with or know how to handle.
morseb1
Dec 30, 2009 11:45 AM
L8APX
21
Aug 15, 2008 12:09 PM
Shy_GuyAP1
Honda S2000
24
Mar 25, 2008 07:04 PM
ILcrxsi1
24
Aug 22, 2006 06:34 PM
lazyfalife
Suspension & Brakes
Jun 24, 2006 09:35 AM
