93 civic si - did wire tuck and might have mixed up some wires
Old Aug 26, 2012 | 08:23 PM
BAD9AZZ1MOFO5's Avatar
Default 93 civic si - did wire tuck and might have mixed up some wires
Size:  43.8 KB IN need of some help....... i did a wire tuck to the hatch and might have mixed up some of the wires. im stuck with the engine harness. its a 8 pin clip(all grounds) i dont know in which order to re pin the clip...i have complete access to fix the problem asap just need someone with the pin out diagram.....
Old Aug 26, 2012 | 10:06 PM
Default Re: 93 civic si - did wire tuck and might have mixed up some wires
OBD1 HARNESS DRIVERS SIDE CLIP............NEED TO KNOW WHAT WIRES ARE SUPPOSE TO BE GROUNDING WHAT(this is ground for this , that one ground for that etc...
Old Aug 26, 2012 | 10:27 PM
jbpnoman's Avatar
You also need to turn off caps lock.
Old Aug 26, 2012 | 10:45 PM
whats does caps lock have anything to do with my thread? i need help with the wires not some smart *** remarks
Old Aug 26, 2012 | 10:46 PM
Canadian_EF's Avatar
a ground is a ground. the order doesn't matter.
Old Aug 26, 2012 | 11:25 PM
egsleepercivic's Avatar
here is a picture from a 93 si, I believe they are the grounds for the injectors
Old Aug 26, 2012 | 11:48 PM
crx_si-r's Avatar
for one, those wires are NOT grounds. those are all 12v power supply wires for the following:
1-4 injectors
o2 sensor
iacv
EVAP
Old Aug 26, 2012 | 11:50 PM
that pic right there is exactly what i need...... but i cant really see.... can u plz check which yellow wires are darker than others? and also need to see the other clips wires more detailed.... i just wanna make sure all my clips are wired correctly before i plug everything in.... thank u egsleeper mad love
Old Aug 26, 2012 | 11:52 PM
crx_si-r's Avatar
it makes no difference what order they are in. if you look under the cap you will see a 2 rows of pins all connected. 1 wire is a main power wire that feeds to all the other wires.
Old Aug 26, 2012 | 11:54 PM
hey crx si, would u know in which order they should be in? my map and other sensor thats on manifold reading supposably at 12v when they should be at 5v....causing my ecu to overheat..... now im looking at all my clips making sure they are wired correctly
Old Aug 26, 2012 | 11:58 PM
crx_si-r's Avatar
for one, your map sensor power supply doesnt come from that connector. power for the map sensor comes directly from the ecu
stevenr2894
10
Mar 9, 2013 10:23 AM
claymonthug
Feb 14, 2010 06:17 PM
CRXed
Nov 10, 2006 07:45 PM
50yocivicfan
Dec 24, 2004 09:01 AM
highmilehatch
Jul 24, 2003 02:09 PM
