Loose Shifter ?
Old Aug 26, 2012 | 07:17 PM
Dougall's Avatar
Default Loose Shifter ?
I have a 1996 honda civic body. with b16a2 and i am 99% sure s4c tranny. I just got it about 2 weeks ago off a friend of mine. Anyways when i can shift into gear perfectly fine and it does not slip out of gear. But when engaged i can move the shifter all around. Its not hurting anything to my knowledge but i fell like i could be getting a lot quicker and smother shifts if it was not so loose. Any advise ????
Old Aug 26, 2012 | 07:53 PM
ef hatchDUDE's Avatar
Default Re: Loose Shifter ?
bushings probably
Old Aug 26, 2012 | 07:57 PM
98civdx's Avatar
Master Detailer
Replace the shifters bushings.
Old Aug 26, 2012 | 08:13 PM
jbpnoman's Avatar
Get yourself a new shifter bushing set from Blackworks Racing. Why? Because it's the EXACT SAME as Energy Suspension bushings, at half the price. When I say "exact same", I mean even the packaging still says Energy Suspension on it.
Old Aug 27, 2012 | 08:06 AM
john159753's Avatar
I am willing to bet your shifter bushings are bad.
Same problem happened to me.. i just picked up some poly bushings and a short shifter while i was at it. :D
Old Aug 27, 2012 | 08:25 AM
tron_'s Avatar
10 Year Member
Like everyone said, check the bushings. Also it could be that the person who did the swap used a bolt instead of a roll pin connecting the linkage to the trans. That will cause a sloppy shifter too.
Old Aug 27, 2012 | 09:52 AM
RT_NEWYORK's Avatar
It's normal. Get your self some energy suspension shifter bushings mine cost 10 dollars
Last edited by RT_NEWYORK; Aug 27, 2012 at 09:53 AM. Reason: Added more information
Old Aug 27, 2012 | 05:48 PM
Hidenplanvew's Avatar
could also be the joint on the shifter rod.. They are pretty easy to re build, just have to grind the pin and tap out with a punch
hillbillycivic
Mar 13, 2013 08:14 PM
x_tuh_sy
Dec 8, 2007 12:03 PM
96electronH
31
Nov 19, 2007 07:31 PM
MrSmith
Aug 7, 2001 07:39 AM
