95 Honda Accord Swap
Old Aug 26, 2012 | 02:34 PM
19HondaAccord95's Avatar
Icon6 95 Honda Accord Swap
I have a 95 Accord and i was wondering if i were to put a 2002 Accord motor in it what would be different that i would have to change?
Old Aug 26, 2012 | 03:15 PM
GhostAccord's Avatar
Default Re: 95 Honda Accord Swap
Is your 95 VTEC or non VTEC? Aside from that you will also have to convert from OBD1 to OBD2. Easiest way would be to get an OBD2 engine wiring harness along with the engine and ECU.
Old Aug 27, 2012 | 04:19 AM
non Vtec
Old Aug 27, 2012 | 10:52 PM
Deepc23's Avatar
i red on a different thread tat the blocks are identical. so aside from wiring and OBD2 conversion would be much different. but just a question, why would you swap your for that engine??
Old Aug 28, 2012 | 12:28 AM
The F23 and F22 aren't exactly identical. The design is however;
F23
97mm stroke x 86mm bore w/55mm main journals
F22
95mm stroke x 85mm bore w/50mm main journals
Old Aug 28, 2012 | 05:44 AM
i jus bought the car and they ran the car low on oil and it broke the cam in half
Old Aug 28, 2012 | 06:48 PM
a guy told me that to make it work all i have to do is keep the headers, dist., and the intake and it will all mount up... is that true?
Turboshaft
Dec 27, 2017 12:47 PM
EXccord
Nov 7, 2017 08:04 AM
SNooPY-JDM
Mar 27, 2014 12:35 PM
Stakhov
Feb 27, 2010 10:36 PM
thehondaguru
Mar 14, 2005 04:32 PM
