How to use OEM filter with AEM rail?
Is there any way for me to use the OEM fuel filter temporarily with the AEM fuel rail? The banjo fitting will not work I need to use a steel braid from what I can see. Can someone point me in the direction of what parts I would need?
Eventually I want to do this set up, but for now I want to get the motor running before the season is over.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/oem-fuel-line-braided-line-aem-fuel-rail-install-2347697/
goto summit and get a -6 to banjo adapter
why you need a fuel rail is beyond me when OEM fuel set up is good to 450hp
you can use the braided line on the oem rail
https://honda-tech.com/forums/tech-misc-15/how-convert-oem-fuel-feed-hard-line-braided-flex-line-fittings-1452210/
https://honda-tech.com/forums/showthread.php?t=1452210
Charlie Moua
Welding / Fabrication
13
Jan 15, 2011 04:31 PM
