option "d" not working in fuse box under dash
Hey guys have a 94 civic hatch. Recently I installed fog lights to my car and everything went well till the relay got wet and I burnt wires. So I had to redo the wiring while figuring out the wiring I blew my fuse to the tail lights etc but I replaced.
Now my alarm was installed by the previous owner and the way the set it up is instead of setting the positive n negative parking lights so when you arm n disarm the alarm they flash well they just ran a single wire to slot d but now Ayer I redid the wiring and did not touch the alarm whenever I arm or disarm it the lights do not flash.
My thread I can bump when I want.
Second I did the wiring correctly the first time which was a week before this incident happened. I washed the car dried etc. Well I went to adjust my headlights and lifted the hood and that's when water dropped to the relay for the fogs; but since it was earlier in the day I figured the water would b dry before I used the lights again. Causing the short n me having the redo the wiring.
red_EF9Si
10
Jan 31, 2006 09:41 PM
