ef swap
Old Aug 24, 2012 | 07:15 PM
lewis91's Avatar
Default ef swap
i have a stock d15b2 single cam four speed trans. id like to swap to a vtec and i was thinking about swaping to a b16a1. but ive been hearing alot about these single cam mini swaps. what would i need to do this swap with my motor and do you think it would be cheaper then just switching to a b16?
Old Aug 24, 2012 | 07:21 PM
24TEN's Avatar
PHANTOM MENACE
Default Re: ef swap
FAQ frequently asked questions. Please learn how to use it. It is located at the top of the forum.
Old Aug 24, 2012 | 09:18 PM
jchope's Avatar
Default Re: ef swap
for the b16 swap you would need a new motor tranny mounts harness compared to a mini me all you need is a new head and ecu i would sagest z6 head im and dizzy and p28 ecu you can wire vtec up your self its not that hard there are many good write ups out there from this point google is your best friend
Old Aug 25, 2012 | 06:14 AM
stealth10-18's Avatar
Default Re: ef swap
Well no matter which route u do your going to have to convert from dpfi to mpfi there are plenty of write ups online on how to do this with a b16 your also going to have to add a knock sensor which isn't difficult either. With a mini me swap you must find a single cam vtec head like a z6 or y8 take it to the machine shop to get resurfaced and slap it on your d15b2 block with a new head gasket and also wire up the vtec solenoid and pressure switch... I would also go with the z6 head and convert the ef to obd 1... almost forgot you must change your dizzy with a vtec dizzy and either get a vtec ecu like a p28 or just chip your stock ecu to run vtec
Old Aug 25, 2012 | 06:53 AM
lewis91's Avatar
Default Re: ef swap
thanks guys that helped alot
draperj09
12
Jun 15, 2006 12:35 PM
9hatch6
Aug 16, 2005 06:35 PM
BLuDoHcReX
11
Dec 24, 2002 09:18 PM
raene
Jul 31, 2001 04:39 PM
