94 accord vtec solenoid
Old Aug 24, 2012 | 05:57 PM
portugueboy10's Avatar
Icon2 94 accord vtec solenoid
hey guys my 94 accord is leaking oil from the vtec solenoid & i wanted to replace the gaskets, wondering if anyone knew what to remove in order to get the vtec solenoid out, thanks
Old Aug 24, 2012 | 06:06 PM
gogydm's Avatar
Default Re: 94 accord vtec solenoid
You should be fine by just removing the three bolts on the assembly. I will warn you that it's a pretty tight fit because of the intake manifold.
Old Aug 24, 2012 | 07:07 PM
nus_dogg's Avatar
Remove the upper half of the VTEC Solenoid then try to get at the other ones using a swivel.
Old Aug 25, 2012 | 04:41 PM
thanks guys wish me luck
Old Sep 1, 2012 | 08:57 PM
i finally completed the job easier to just remove the thermostat housing, to get to the bottem bolt
Brandon Stibich
Oct 26, 2018 06:41 AM
souljah07
May 31, 2007 07:27 AM
DrewQ1
Dec 20, 2003 10:32 PM
DrewQ1
Dec 15, 2003 03:36 PM
