MD H22(Fully Built)
I am selling my fully built prelude. It was my goal to have the fastest 4th gen prelude in the state of Maryland then move on out. But I got a new job and have no time to finish my dream. So its been sitting in the garage waiting to be finished with little to finish. i will give you a short rap of what’s done to the car as of now. Over $15000 invested and no knock off junk.
-precision 6262 turbo(never ran just bolted to the manifold)
-blueridge motorsports topmount turbo manifold
-injector dynamics 1000cc
-skunk 2 intake manifold
-hondata s300j computer(never got used)(pre installed before ordered) with boost control solenoid
-32 x 12 inch intercooler
-all piping for intercooler
-50mm blow off valve(emusa) custom fabbed flange from cnc machine
-AeM high flow fuel rail
-Aem Fuel pressure regulator
-every guage you could think..boost.oil pressure.oil temp. water temp…..
-all new starter.alternator. high performance coil by accel. New wires.
-shaved and tucked engine bay.
-New fuel lines from lower firewall up.
-aeromotive high flow fuel pump 300lph
-new ignition lock(when I got the car the girl broke the key off inside)
-38 mm emusa wastegate
-custom fabbed downpipe done right with nascar fold under radiator so wouldn’t get to hot and melt
-custom fabbed open dump tube
-battery relocated to trunk for tuck
-stage 5 competition clutch never used and installed
-8lb fidanza flywheel
-motor has all new seals
Now with the ENGINE GOODIES
-fully built block and head
BLOCK
-darton MID sleeves stock bore.CNC engine dynamis recommended with power goals and they installed
-cp pistons
-eagle rods
-ACL race bearings
-h22 balance shaft removed with Kaizen speed kit
-new oil pump
-oil pan tapped for return
-cometic headgaskett 3mm
-ARP head studs
CYLINDER HEAD
-fully built also
-sknuk 2 pro series valvesprings
-skunk 2 pro series valves(intake and Exhaust)
-ferrea valve guides
-ferrea valve seals
-brian crower cams(stage 2)
As you can see my by this write up I didn’t skimp out on anything. The only thing the car needs is paint and short amount of body work, and tuned, its never been ran, so 0 miles on this build just like I said its ready to go after tune…I have new front bumper, and front fender, and found a hood with no dents, and found other fender with no dents…put a little work into this and you have a hell of a fast car. Only consider real inquiries….asking way below what I got into it….oh and has all new suspension parts. Ball joints, arms, megan racing coilovers, all new brake hoses, Throw offers or decent trades. Just no time for the Honda game anymore with new job and need a daily that’s reliable and boosted. 12403626177 is my cell or email me at brandon999@atlanticbb.net.... Text for pics. Cant seem to get any of mine loaded or email
BLOCK
-cp pistons
-eagle rods
-ACL race bearings
-new oil pump
-ARP head studs
CYLINDER HEAD
-fully built also
-ferrea valve seals
sonnyboi612
Feb 26, 2006 04:07 PM
