Suspension & Brakes Theory, alignment, spring rates....
lowering spring problem
Old Aug 24, 2012 | 11:03 AM
Lx Civic 99's Avatar
Default lowering spring problem
Alright i installed some Tein lowering spring last weekend and my passenger side is lower than the driver side. ( I can fit 2 fingers on driver side and 1 finger on passenger side) I had a problem with the passenger side when i bolted the strut up top to hold it and put it in the damper fork. when i went to line it up with the lower control arm i had the push the hub do kinda far to get the holes to line up. I didnt have any problem put the strut on the driver side back in.
what could the problem be with the passenger side bad strut or something?
Let me know thanks
Old Aug 24, 2012 | 01:29 PM
bnetkillzone's Avatar
Default Re: lowering spring problem
That's the thing about lowering springs, it won't be perfectly level because different corners of the car weight differently.
Even with coilovers if you set them equal on the threads you will have an uneven ride height. So you have to set them at different heights.
However you don't have this luxury with lowering springs.
Old Aug 24, 2012 | 01:47 PM
<LsD>'s Avatar
Exactly the same problem was on Tein. When put skunk2 or H & R springs and has exactly the same fingers intermeddle with different sides of the vehicle
hoga113
Suspension & Brakes
14
Mar 30, 2013 10:59 PM
Lextasy
Suspension & Brakes
12
Oct 14, 2009 09:41 AM
seven12
Sep 28, 2005 06:36 PM
B18C5-EH2
Oct 28, 2004 02:46 PM
