eg/dc2 rear lca on the type r
Old Aug 24, 2012 | 07:58 AM
Root of all Evil's Avatar
Default eg/dc2 rear lca on the type r
I bought the eg/non r dc2 rear lca from kiwi. Have the correct shock mount, just need the right endlinks for the stock 22mm sway. Would the gsr endlinks bolt it up? I would rather not use washers if there is a more stock method. Thanks!
Old Aug 24, 2012 | 08:55 AM
94rs-turbo's Avatar
Default Re: eg/dc2 rear lca on the type r
NON-ITR LCA's will bolt up with stock itr sway and links
Old Aug 24, 2012 | 02:22 PM
the bar will bolt up but the endlinks are put on a angle and it doesnt look like something i want to use. the stock itr arm is much thicker than this aftermarket lca. Therefore a spacer or different link to compensate for the decreased lca thickness would be needed. lca is password jdm kiwi signature.
Old Aug 24, 2012 | 06:21 PM
Todd00's Avatar
I said I don't want a title!
Most/all aftermarket rear LCA's that I've seen have that issue. It is not because you bought non-ITR LCAs. Even the ITR correct ones have that issue.
I used a metal spacer and a longer bolt to get mine perpendicular.
Old Aug 25, 2012 | 05:26 AM
Ok thank you, I will go ahead with that.
freshane
Suspension & Brakes
28
Oct 11, 2012 07:29 PM
makoto
Suspension & Brakes
Jul 21, 2008 12:25 PM
btcca4
May 14, 2005 05:55 PM
808State
Feb 11, 2005 05:38 PM
teg92
Jan 17, 2004 03:43 PM
