Complete B18 swap freshly rebuilt engine
Old Aug 23, 2012 | 10:33 PM
gnxpro24's Avatar
Default Complete B18 swap freshly rebuilt engine
For Sale: LS swap. STILL IN CAR, HEAR IT RUN! Fully rebuilt this past spring. Arp head studs Arp rod bolts brand new oem rear main seal and head gasket brand new npr rings bearings and valve stem seals brand new oem dizzy o ring and cam seals. Crank was polished and cut by Dodson machine shop. He also machined the rods for the Arp rod bolts. Brand new valve cover gasket set. $1500 in rebuild alone. Swap includes engine transmission ecu and dizzy hasport mounts and shift linkage for ef chasis. STRAIGHT DROP IN FOR ANY EF! $1800 for everything. Text 814 799 3537
Hasport mounts- 250
Hasport shift linkage- 100
Swap without mounts and linkage-1500
Old Aug 24, 2012 | 02:17 PM
gnxpro24's Avatar
Default Re: Complete B18 swap freshly rebuilt engine
In the car running see it run!
Old Aug 29, 2012 | 10:49 AM
gnxpro24's Avatar
Old Aug 30, 2012 | 07:50 AM
gnxpro24's Avatar
