1992-2001 Honda Prelude parts h22 h23 right hand drive prelude conversion
Old Aug 23, 2012 | 09:55 PM
customs-25's Avatar
Default 1992-2001 Honda Prelude parts h22 h23 right hand drive prelude conversion
Hello, I have a ton of prelude parts for sale, I have other parts that are not listed, 925-321-5289
1999 PRELUDE RIGHT HAND DRIVE CONVERSION DASH AND SUPPORT BAR, STEERING SHAFT ALL WIRE HARNESSES STEERING RACK EVERYTHING NEEDED $150
1997-2001 FRONT SHOCKS AND SPRINGS FROM SIR S SPEC CLIP 30K MILES $100
PRELUDE SIR S SPEC HUBS COMPLETE WITH CONTROL ARMS ROTORS AND BRAKE CALIPERS FROM A 30K MILE CLIP $200
OIL COOLER KIT COMPLETE MOUNTS TO BUMPER SUPPORT NEW FILTER, RELOCATED YOUR OIL FILTER TO THE FRONT OF THE CAR $150
BLACKTRAX RACING INTAKE MANIFOLD SPACER DELETES BUTTERFLY VALVES $40
A/C BOX DASH OUT OF A 30K MILE CLIP NEAR NEW $45
FAN BOX DASH OUT OF A 30K MILE CLIP NEAR NEW $45
HEATER CORE DASH OUT OF A 30K MILE CLIP NEAR NEW $45
A/C COMPRESSOR WITH LINES $45
A/C COMPRESSOR ALUMINUM BRACKET 1997-2001 $40
SPEED SENSOR 5-SPEED $40
E-BRAKE HANDLE JDM 30K MILE LIKE NEW $40
BRAKE BOOSTER OEM HONDA removed from 1999 sir s spec $40
STARTER 1997-2001 5-speed 120K MILE $40
BRAKE FLUID MASTER CYLINDER RESERVOIR HONDA OEM FROM 30K MILE CLIP $30
THROTTLE PEDAL WITH FRAME 30K MILE CLIP $40
POWER STEERING RESERVOIR $25
POWER STEERING BRACKET $30
AXLES DRIVER AND PASSENGER HALF SHAFT $40 FOR A PASSENGER AXLE $40 FOR A DRIVER SIDE AXLE WITH HALF SHAFT (DAMAGED WHEEL SIDE THREAD) $40
FUEL LINE AND FILTER 1997-2001 $35
CHARCOAL BOX AND LINE $30 OFF A 30K MILE CLIP
INTAKE VACUUM BOX 1997-2001 $30
BATTERY HARNESS AND GROUND 1997-2001 $25
ENGINE HOSES 6 FOR $25
1997-2001 HOOD LATCH $20
BATTERY HARNESS GOES TO THE FUSE BOX and Battery GROUND HARNESS $25
WINDSHIELD WIPER AND DASH VENT COVER 30K MILE NO CRACKS OR DAMAGE $40
FIREWALL ENGINE COOLANT HOSE WITH HEATER VALVE 30K MILE $30
SIR S SPEC STRUT BAR 30K MILE $45
GUTTED CATALYTIC CONVERTER $30
AXLES AND INTERMEDIATE SHAFTS $45 EACH I HAVE 4 OF THEM
H22A4 HEAD BOLTS WITH WASHERS $25
H22A4 FULL VALVE TRAIN 70K MILES $40
1997-2001 PRELUDE CARPET AND FLOOR MATS $30
FRONT REAR AND DRIVER SIDE ENGINE BRACKET $30 a piece
ALUMINUM TRANSMISSION/ENGINE BLOCK COVER 1997-2001 $30
GREDDY TURBO BLUE BOX ENGINE MANAGEMENT 1997-2001 PRELUDE $75
1992-1996 PARTS
1992-1996 COMPLETE STOCK INTAKE WITH FENDER RESERVOIR AND DIAPHRAGM $40
NEWER RADIATOR WITH FANS $50
1992-1996 A/C COMPRESSOR WITH LINES LOW MILES $50
4WS 5-SPEED SI ECU WITH FRAME $40
H23A3 ALTERNATOR BRACKET $30
H23A3 A/C PUMP BRACKET $30
1992-1996 5-SPEED SPEED SENSOR NOT BROKEN $45
H23A3 HEADER AND DOWNPIPE WITH NEW O2 SENSOR $45
H23A COMPLETE CRUISE CONTROL $20
H22A OEM OIL PUMP WITH PICKUP 40k miles no damage $40
H22a OIL STICK AND TUBE $20
H22A AUTOMATIC TIMING TENSIONER KIT COMPLETE $30
H22/H23 MANUAL TENSIONER KIT COMPLETE LIKE NEW $50
H22A ALTERNATOR BRACKET $25
H22A A/C BRACKET $25
Old Aug 24, 2012 | 05:24 PM
customs-25's Avatar
Default Re: 1992-2001 Honda Prelude parts h22 h23 right hand drive prelude conversion
UP
Old Aug 25, 2012 | 09:32 PM
customs-25's Avatar
UP
Old Aug 25, 2012 | 09:54 PM
PilotOnDubs's Avatar
is the 92-96 stock intake for a h22?
Old Aug 26, 2012 | 06:03 PM
customs-25's Avatar
up
Old Aug 27, 2012 | 05:28 PM
customs-25's Avatar
bump
Old Aug 30, 2012 | 05:05 PM
customs-25's Avatar
bump
Old Sep 4, 2012 | 03:11 PM
customs-25's Avatar
everything still for sale
Old Sep 9, 2012 | 05:43 PM
customs-25's Avatar
bump
Old Oct 3, 2012 | 08:12 PM
TeamFBI's Avatar
You still the right hand drive stuff for the 99 prelude?
Old Oct 3, 2012 | 08:15 PM
TeamFBI's Avatar
You still have, sorry
Old Oct 3, 2012 | 08:31 PM
customs-25's Avatar
Yes i do 925-321-5289
Old Oct 4, 2012 | 06:01 PM
pcbabb's Avatar
do you have the motor mount post (the part that bolts to the block that the motor mount bolts to)
Old Oct 4, 2012 | 06:07 PM
customs-25's Avatar
If you mean the front or rear bracket that bolts to the block yes.
Old Oct 4, 2012 | 06:51 PM
pcbabb's Avatar
it mounts on the end of the block by the timing belt I circled it in red
Old Oct 4, 2012 | 06:55 PM
DC2Bobby's Avatar
Water pump?
Old Oct 4, 2012 | 07:20 PM
pcbabb's Avatar
If you have that bracket, I'd like to get it and the 97+ power steering bracket. I have paypal
customs-25
Aug 18, 2013 04:00 PM
customs-25
Aug 18, 2013 03:58 PM
customs-25
Northern California (Sales)
Dec 4, 2012 06:21 PM
customs-25
Oct 29, 2012 05:02 PM
numberonefjb
Feb 7, 2004 06:54 AM
