purpose of extended wheel studs and lug nuts?
Old Aug 23, 2012 | 08:10 PM
muddmonky's Avatar
Icon2 purpose of extended wheel studs and lug nuts?
like the title stats what is the point of these is it just for looks so your lug nuts stick out further or what i dont understand. if anything you'd think it would be weaker since its easier to break a long skinny thing compared to a short stubby thing.
Old Aug 23, 2012 | 09:15 PM
B and B's Avatar
Loved
Community Favorite
Default Re: purpose of extended wheel studs and lug nuts?
http://www.hondatuningmagazine.com/t...s/viewall.html
Old Sep 2, 2012 | 07:17 PM
sackdz's Avatar
Pros:
-easier to install the wheel
-allows safer use of wheel spaces by using all the threads of the wheel nut
-more warning of a loose wheel nut before it falls off
Cons:
-takes more turns to install and remove wheel nut
Assuming you are not buying junk, strength will be the same or better than and OEM. Extra length makes no difference in strength - you aren't using the threads past the lug nut.
It is preferred to use the style of extended stud with tapered ends, easier to install wheel and wheel nuts.
Be sure to check the knurl diameter. Some extended stud kits may require you to drill the hub holes out as the knurl diameter is larger than stock.
Old Sep 2, 2012 | 10:35 PM
slowcivic2k's Avatar
Using spacers to adjust wheel offset will generally require the use of extended studs to make up for the spacer thickness. These studs should be very strong, as moving the rim off the hub flange will cause the wheel stud to bear the load of the vehicle, making snapping a stud a very real possibility.
You should always use rims that are hub centric with the correct offset from the manufacturer, this puts the weight on the wheel hub flange, where it should be.
Using lug centric wheels leaves too much risk in the area of snapping a stud, or losing a wheel.
Eclectia
Jun 16, 2013 11:56 AM
93grayeg
May 12, 2011 09:37 AM
drewbie
Welding / Fabrication
Apr 21, 2006 07:28 AM
mingbling
Jul 27, 2004 09:05 PM
david90
Jun 8, 2004 03:50 PM
