Gear oil for 89 Civic manual trans
Old Aug 23, 2012 | 07:37 PM
SheepDawg's Avatar
Default 89 Civic manual trans, stripped fill plug
Hi,
can anyone tell me what type of gear oil I should use to refil my manual trans?
I have an 89 Civic, i was recomended 10w30 but as I drained the old stuff out i couldn't help but notice that distinct stank of gear oil... So now I am suspicious...
Thanks
Old Aug 23, 2012 | 07:47 PM
ryanevansoh's Avatar
Default Re: Gear oil for 89 Civic manual trans
10w-30 or manual transmission fluid from Honda. Or GM synchromesh
Old Aug 23, 2012 | 07:52 PM
SheepDawg's Avatar
Thanks, there is so much debate over it I see from reading threads. I guess I'll go with a 10w-30.
Old Aug 23, 2012 | 07:54 PM
crxguy406's Avatar
Just get genuine honda MTF from any of your local dealers. Costs about $7 a quart and it has all the proper additives a honda tranny needs.
(honda MTF is basically 10w-30, but with a CRAP load of additives.)
Old Aug 23, 2012 | 08:46 PM
94eg!'s Avatar
#1 Super Guy
Loved
It's actually quite the opposite. Motor oil contains a crap load of additives that are completely unnecessary for a transmission. MTF has additives specifically designed to help synchros do their work while not turning into a foamy mess from the whipping action of the gears.
Old Aug 23, 2012 | 10:04 PM
SheepDawg's Avatar
are there other suitable options than going to the stealership? 75w90 is about the lightest gear oil I've come across on the shelf.
I'm in no rush, my first hurdle to get over is the rounded over fill plug. looks like someone used a 12pt combination wrench on it a size too large. Or standard instead of metric. I jacked the car up and managed to get a socket on there but not enough meat left to turn the plug. I'm not sure where to go from here other than sacraficing and welding a wrench to the drain plug to break it loose. Whoever tightened it tightened it so hard the aluminum lip on the tranny is cracked.
Looks as if I made the dumbshit mistake draining the oil before it could be refilled. Though i thought I removed the drain and fill plugs turns out what i thought was a fill plug isn't.
Old Aug 24, 2012 | 01:48 AM
ellupo's Avatar
Go with 10W-30, that's what the manual says should be used.
On crxcommunity we have a guy that builds and re-builds trannys for a living and he discourages from using Honda MTF strongly.
This is what he had to say in a thread with the exact same question as you had:
I had a call tonight, a person wanting TWO SCCA ITA trannys gone through that King Motorsports had built two years ago. Both are now making noise, crunchy shifts, etc.
Both cars are using third generation Honda MTF, aka pisswater. One tranny is out, other car not yet up in the air. I told him to drain the fluid, dump in 2 quarts of 10w30 and report back. I fear ISB is already damaged as one pops out of first gear when driven thru paddock.
Torco Fluids will be tested at end of July, beginning of August at Mid Ohio. Besides the Moser clan in their ITA CRX's I hope to one day have all the Ohio Honda ITA entries at IT Fest running trannys I've built/serviced.
Regarding the smell: If motor oil gets really old, it starts to smell kinda like gear oil. I had the same thing on my CRX when I changed the tranny oil. That oil was in there for probably 15 years
Old Aug 24, 2012 | 05:40 AM
94eg!'s Avatar
#1 Super Guy
Loved
75w90 "gear" oil is the same thing as 10w40 motor oil. Nothing new or special. Honda MTF is a 75w80 gear oil (10w30 equivalent). Thinner for better fuel economy.
Old Aug 25, 2012 | 09:42 PM
SheepDawg's Avatar
Thanks fellas
Old Sep 1, 2012 | 08:20 PM
Robotn1x's Avatar
ive been wondering the same thank you
Old Sep 2, 2012 | 06:19 PM
choocko's Avatar
Go to honda and get it. thats your best bet.
Old Sep 3, 2012 | 07:09 AM
zrickety's Avatar
The newer transmissions use Honda MTF, the older ones use 10w30 oil. I would recommend castrol gtx. No reason to use more expensive or different fluid.
Old Sep 3, 2012 | 04:48 PM
Corksil's Avatar
I put honda MTF in mine.
then I was told it's too thin for our older transmissions because honda keeps changing the formula.
so i flushed/filled with 5w-30 eneos synthetic
then i was told synthetic is too harsh on the syncros .
so i flushed/filled with conventional 5w-30 and that's working well with a 25% concentration of lucas stabilizer.
Old Sep 3, 2012 | 07:16 PM
flatblackfury91's Avatar
royal purple syncro mesh. expensive but worth it. my buddies tranny grinded goin in third. changed from motor oil to rp syncro mesh, a week later, no grind. it works. i will never put motor oil in a tranny again.
Old Sep 4, 2012 | 09:44 AM
hatchbklvr's Avatar
personally i always u a quality full synthetic 10w-30 motor oil in my cars but what ever u do stay away from gear oil it will cause ur syncros to burn up really quickly
Old Sep 6, 2012 | 09:30 AM
maiden424's Avatar
just use the 10w30.. best bet..
Old Sep 7, 2012 | 07:14 AM
sde780's Avatar
Pennzoil Syncromesh. Don't fall for the expensive "friction modified" GM blend, it made no difference in my GSR.
Old Sep 7, 2012 | 09:02 AM
94eg!'s Avatar
#1 Super Guy
Loved
^No difference in what? The GM FM stuff helps if your having notchy or crunchy shifts. That is no joke. I've used it twice where the Honda stuff wasn't smooth enough.
Old Sep 7, 2012 | 12:36 PM
sstupid's Avatar
10 Year Member
I use recycled 10-30W in my trannsmission. It's at 180K right now. My car pumps out a whopping 52 hp to the wheels, so I don't see any reason to be worried about the "high-perf" gear oil.
Old Feb 11, 2013 | 12:42 PM
BakedAlex's Avatar
what kind of car did you use it in? I'm rockin the honda mtf in my 90 si and it still shifts a little rough
Old Feb 11, 2013 | 12:57 PM
94eg!'s Avatar
#1 Super Guy
Loved
1st time was an 03 Element AWD 5MT. The clutch slave took a dump and the resulting limping to dealer ate up 3rd. After replacing the synchro, the gear was ALWAYS notchy. My wife complained of it popping out of gear or not going in at all at least once each time she drove it (dealer said it's normal.....NOT!). I switched to GMSMFM and never had a single bad shift again.
05 Acura TL 6MT with typical 3rd gear problem. I had tried the then reformulated Acura/Honda MTF (white cap) and it worked great for exactly 1000 miles. Then it started acting up again like before. Dealer checked it and replaced the 3rd gear synchro under warranty. It was fine for a few years. Finally in the freezing cold of Reno, I had a single notchy shift and I immediately switched to the GMSMFM. It's been perfect ever since (over a year).
If shifts are rough, give it a shot. You have nothing to loose.
MMMGIRL
Apr 11, 2014 06:06 AM
Crossbreeder
Sep 24, 2009 09:18 AM
thiscivicuser
17
Mar 3, 2008 08:45 PM
boosted94teggy
Oct 27, 2005 12:42 PM
petrv
May 30, 2003 01:56 PM
